360Fish Semi-Pro Touring
Author Topic: 360Fish Semi-Pro Touring  (Read 83085 times)
Offline 360FISH
  • BS23H3B567746
« on: January 30, 2011 - 12:40:53 AM »
Hey all...  here are a couple shots of some rust I have on the inner door panel.  I want to remove it, seal it, etc.
There are a lot of different products in the Eastwood catalog but thought you guys would know what really works and what's the best way to use them.   What has worked for you guys on your door panels?
looking down thru the window slot...
Thanks
Alan
« Last Edit: April 30, 2013 - 02:24:03 AM by 360FISH »
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline pywell
  • Autobody Technician
    • PPC Customs
Re: 360Fish
« Reply #1 on: January 30, 2011 - 12:49:48 AM »
I dont know what eastwood has off hand I use RUST-MORT to convert the rust, then there is a rust wax (I will try and get the actual name of it, I have to wait until the distributor here is open to find out and that is not until monday) that you spray in the doors, frame rails, rockers and where ever that stuff is rust cant start. Those are the 2 items I have used and they have worked 100% everytime, I have used it on a hundreds of vehicles.
« Last Edit: January 31, 2011 - 12:12:19 AM by pywell »
Offline 360FISH
  • BS23H3B567746
Re: 360Fish
« Reply #2 on: January 30, 2011 - 01:12:44 AM »
There fixed it for you, you cannot post a URL in the IMG feild. That would be a link not an image.
Ooops...  I should have known better..  thanks.
Yes, would like to know what the other product is when you have a chance to get the name.
Much appreciated.
Alan
Offline pywell
    • PPC Customs
Re: 360Fish
« Reply #3 on: January 31, 2011 - 12:11:19 AM »
I still have to contact the distributor tommorow. But since I was at the shop today I took a pic of this for you.
Offline 360FISH
  • BS23H3B567746
Re: 360Fish
« Reply #4 on: March 10, 2011 - 02:13:33 AM »
I know it’s not building parts from scratch or welding patches on to the body, but I really loathed the idea of install my driver’s door glass…    :-[
…after cleaning some parts (yes Charlotte there are a few clean parts on this car) I bit the bullet and installed the glass I bought from Bill (mopar12372).   :woo:
I have to tell ya, the man up stairs liked me today…  I found perfect bolts at just the right time in the pile I’ve built up over the years.   And there were more than a few times where I thanked the designer for giving me that quarter inch here and there that I needed to get to get stops, pads, etc. installed…
There were a number of glitches and restarts, but in the end…
THIS WAS A GOOD DAY!    :woohoo:
Now I can take the car some place and lock it up.
What is this rubber piece called and will it cost an arm and a leg to replace?    :clueless:
Offline the Wizard
  • Business Manager
  • Imagination is more important than Knowledge - Albert Einstein
Re: 360Fish
« Reply #5 on: March 10, 2011 - 02:37:51 AM »
Eastwood has a couple products you should check out...."Rust Convertor" and "Rust Encapsulator".  I just ordered both of these last night for some spots on our new Challenger.
Here's a couple links to get you started.....
http://www.eastwood.com/eastwood-rust-converter.html
http://www.eastwood.com/eastwood-rust-encapsulator.html
and if you click the link here or use the coupon word "cuda" you get a discount.....
« Last Edit: March 10, 2011 - 02:39:32 AM by the Wizard »
Offline 360FISH
  • BS23H3B567746
Re: 360Fish
« Reply #6 on: March 11, 2011 - 02:47:25 AM »
Thanks for the links.  I'll order some over the weekend.
I pulled apart the passenger side door glass and found a mess.  Now I have some parts to buy...
The front two rollers are shattered...  I think Roseville has them listed as part 723695...
http://www.rosevillemoparts.com/product_info.php/p/roller-w-screw/products_id/1984
Does anyone know the part number for the front plastic fastener used to attach the glass to the horizontal lifting guide?
Thanks!
Alan
Offline pywell
    • PPC Customs
Re: 360Fish
« Reply #7 on: March 11, 2011 - 11:24:29 AM »
Let me know too, I want to replace them on my project, 1 is busted and the other didnt break but it would  be best to replace both since we know the other is not far behind and I only want to do this once lol.
I did finally check my supplier for the rust proofing and the only thing I could get from them on the rust proofing wax is called rust proofing. I think she was a little too busy to go look it up for me. Best way to do it is to phone your local body shop supplier and ask for rust proofing spray, its black and has a wicked smell that most people dont like (Im so far the only one who seems to like the smell of ours, but Im old school and never used masks or gloves for most of my carreer and got used to many things that now we think is stupid to expose ourselves too. (I now use the gloves and masks, got a little (just a little) smarter over the past decade or so.
The rust proofing is not to be confused for a rust converter etc... its suppose to  be sprayed inside your doors, rockers, frame rails etc... where you dont want rust to show up after your restoration is done and you spray it once a year a so for good measure on areas exposed to moisture (frame rails and rockers, inner door panels, trunk floor to quarter panel drops, behind the front fender areas. Anywhere it is prone to rust on these models and your vehicle will last longer then you will.
« Last Edit: March 11, 2011 - 11:36:42 AM by pywell »
Offline mopar12372
    • mopartech
Re: 360Fish
« Reply #8 on: March 18, 2011 - 10:57:52 PM »
right on al  :2thumbs:
the surface rust you have there could be taken care of with rust inhibitor . its a jelly that you can brush on and leave on and paint over it with rustoleum (how ever its spelled ) . in areas like that that i cant get to with out takeing half the car apart thats what i did  + unlike other people that live in ice cubes we dont have to really worry about it . you do have a ocean near you soo i would protect it with what i sugested . there are other ways and products to do this with though.
RESTO PICTURES
Offline usraptr
Re: 360Fish
« Reply #9 on: March 19, 2011 - 03:40:43 PM »
Rust Bullet also works well to encapsulate the rust.  A bit pricey but it does a good job.  Congrats on getting your window glass done.   :2thumbs:  I'm also dreading doing that when the time comes.  I rather rebuild the engine than tackle that job.   :lol:
(Edited 8-1-17)
Offline 360FISH
  • BS23H3B567746
Re: 360Fish
« Reply #10 on: March 21, 2011 - 12:51:46 AM »
Thanks for the info guys.  Parts are on the way and when it drys out around here I start messing with the rust.
Offline 360FISH
  • BS23H3B567746
Re: 360Fish
« Reply #11 on: March 21, 2011 - 11:40:11 PM »
The mail is in!
Small parts, but important.  ... and now I have something fun to do!
Hat tip to moparnut for the heads up on the license plate frame.
Offline 360FISH
  • BS23H3B567746
Re: 360Fish
« Reply #12 on: March 25, 2011 - 12:57:00 AM »
Hmmm...  what's the right way to get the remains of this roller off the arm it's attached to?
It's not threaded and it doesn't want to pull off.   :stomp:  What's the secret?   :swear:
Thanks
Offline pywell
    • PPC Customs
Re: 360Fish
« Reply #13 on: March 25, 2011 - 09:51:49 PM »
I'll try and have a look at mine when I get back to the shop this weekend. Welded? eek may have to drill it out? good question.
Offline mopar12372
    • mopartech
Re: 360Fish
« Reply #14 on: March 25, 2011 - 09:55:22 PM »
you have to drill it and take it off. if you want i can do it for you. :wavingflag:
RESTO PICTURES
