360Fish Semi-Pro Touring
Author Topic: 360Fish Semi-Pro Touring  (Read 83121 times)
Offline 360FISH
  • BS23H3B567746
Re: 360Fish Semi-Pro Touring
« Reply #165 on: April 01, 2014 - 02:05:22 AM »
I've had many cooling issues over the years and decided to ditch the clutch fan and go electric.
I chose the HHR fan for the same reason many do...  it's only $55 at Rock Auto and it sucks air like a jet engine.
The fan is controlled by the FAST EFI system.
Found the correct plug connector at a junk yard... bought a few at a buck each.  :)  the middle one was too small a gauge so that was rejected.
Note..  the wire in the connector might need to be swapped to color code them correctly.  The HHR fan will run backward if you cross up the wires.  ;)
It barely clears the front of the water pump... (I have a 4 core raditor)  It wasn't enough clearance to work...
A number of people have made a simple modification to the back of the fan to make clearance and it sure enough works out great.
The "fins" you cut off don't seem to make any structural difference.  One post on the net says they are cooling fins, but I don't know.  The part you expose is not the spinning part of the fan... it is a solid housing.
I put some paper in the slot to help cover anything below and to help see what I was cutting.
clearance :)
After I finished the initial cut I realized I neede to get rid of a couple more bits to finish this off...
There are some tabs on the shroud base to remove to gain a little more space.
Note some cutting around the base of the shroud to fit the outlet radiator hose and the tranny cooler bungs.
The final product!
I've had no issues with cooling...  this thing is amazing...  and a BIG load off my mind.
Another thing off the list!
« Last Edit: April 01, 2014 - 02:09:11 AM by 360FISH »
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline 360FISH
  • BS23H3B567746
« Reply #166 on: April 01, 2014 - 02:10:11 AM »
Since I keep adding electrical to the Fish...the HHR fan was next...  and the fact that my old alternator finally died and left me stranded with a dead battery...
I installed a 120 amp Nippondenso alternator.  (My amp gauge was bypassed long ago...)
I followed some other posts on the net about how to make it happen and it fit.  The hole to bolt the alternator to the arm is in a different location so I had to extend my old alternator braket with part of an aftermarket braket.  This was cut and fitted onto the old one to extend the sweep to tighten the belt.
Low RPM voltage is enough to keep the charge going...  I'm at approx 14.2 volts at normal RPM
Sweet!
Offline 360FISH
  • BS23H3B567746
« Reply #167 on: April 01, 2014 - 02:14:31 AM »
whew... that was a lot to complete before MATS...
gratuitous picture of the Fish...  sadly it looks much rougher in person...  I'll have to work on evening out the exterior appearance next...
« Reply #168 on: April 01, 2014 - 04:17:46 AM »
I wonder if you could have used button head cap screws to gain the clearance you needed?
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #169 on: April 01, 2014 - 07:25:28 AM »
I was thinking the same thing.. Looks good.. :bigsmile:
Offline turbo224
« Reply #170 on: April 01, 2014 - 10:16:08 AM »
Nice work! I'll be looking for the car at MATS this year.  :thumbsup:
~Tyler Larsen~Salt Lake City
-1971 Plymouth Cuda 440-6pk Tribute
-1992 Dodge Daytona IROC R/T
Offline 360FISH
  • BS23H3B567746
« Reply #171 on: April 01, 2014 - 08:28:19 PM »
I was looking for anything that had a flatter head but came up empty...  Even with that the clearance was so tight I'd have to complete the surgery.
Offline A110235
  • '71 Challenger JH23G1B
« Reply #172 on: April 02, 2014 - 11:37:09 AM »
Looking good man!  Have you had any issues with the Edelbrock universal fuel pump/sump?
Kyle
Nashville, TN         Member since October 09, 2004
Offline dutch
« Reply #173 on: April 02, 2014 - 02:09:42 PM »
nice work!  It looks bad a$$ the way it sits there  :ylsuper:
I would look into adding a plate onder the waterpump pulley bolts.  Shaped like the base of the factory fan.  I`ve seen several pulleys crack when used without the fan   :2cents:
 :wave:
*** Bart ***
Offline MizzouRT
« Reply #174 on: April 02, 2014 - 04:56:47 PM »
This is such a fun project.  Always great to read about cars that get driven.
Daily Driver: 2013 Challenger SRT 6 speed
Toy: 1970 Challenger
Offline 360FISH
  • BS23H3B567746
« Reply #175 on: April 02, 2014 - 08:31:21 PM »
Kyle
Hey Kyle... none so far...  the big test is next week with a long road trip of approx 1500 miles.  Fingers (and toes) crossed!   :cooldancing:
 :wave:
Thanks Dutch...  that picture does make it look great.  ;)
So is the ideaof the plate your'e describing to spread the load across the front of the pully "bell?" and keep the bolt/washer from stressing the area around the hole?   That would seem to make sense...
Offline 360FISH
  • BS23H3B567746
« Reply #176 on: April 02, 2014 - 08:33:14 PM »
Ha!  Thank you.   You gotta drive it like you stole it!  ;)
« Reply #177 on: April 02, 2014 - 08:36:31 PM »
 :iagree: :aarg:  :bigsmile:
Offline dutch
« Reply #178 on: April 03, 2014 - 01:48:35 AM »
exactly  :2thumbs:
*** Bart ***
Offline Travis72
« Reply #179 on: April 04, 2014 - 03:09:54 AM »
Nice work!  I'm trying to make it to MATS this year as well.  I'll try and find your car!
Travis
72 Cuda
