Quicktime Bellhousing RM 6073
Author Topic: Quicktime Bellhousing RM 6073  (Read 5110 times)
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
« on: January 30, 2011 - 08:45:45 AM »
Hi guys.
Ive got my bellhousing fitted and im wondering how you bolt up the starter motor?????
Normally theres a stud and a bolt! Ive got 2 threads that take 3/8 bolts?
Has anybody had experience with this?
Do i make bushes that take up the extra diameter from bolt to starter?
Any help really appreciated!
Ive searched the web everywhere for an answer??? :dunno: :clueless:
« Last Edit: February 13, 2011 - 11:02:46 PM by punisher72 »
Re: Quicktime Bellhousing RM 6073 HELP PLEASE!
« Reply #1 on: January 30, 2011 - 03:20:48 PM »
Not cool , the bolt size should be 7/16 , I would tap the holes out to the larger size , I assume there is a cup inside the bell to center the starter nose , if so you just need to keep the starter tight , no bushings required
Offline punisher72
« Reply #2 on: January 30, 2011 - 03:55:03 PM »
There is no cup to locate the end of the starter Chryco! I've read elsewhere that other QuickTime bellhousings don't have that cup and that they have had no problems. They don't mention the smaller thread size but?? My motor is in at this stage which makes it hard to sort out :(
« Reply #3 on: January 30, 2011 - 04:15:30 PM »
then you would have to use a bushing to center it & it puts stress on the starter where it is not designed to support the load , I would contact the manufacturer of the belhousing to see how they handle it
Offline punisher72
« Reply #4 on: January 30, 2011 - 04:25:41 PM »
Thanks Chryco. I tried ringing last night then i checked the time in Ohio and its still sunday there  :bigsmile:
I will try late tonight when you guys are getting over your sunday beer session  :cheers: :drunk: :bigsmile:
Offline 73EStroker
« Reply #5 on: January 31, 2011 - 12:57:19 PM »
I can't remember but the locating hole opening for your starter looks like part of the hole is covered by the block. Does your starter fit in there and if so how can you be sure the alignment with the ring gear teeth is ok?
Barry (Salmon Arm)
Offline 73restomod
« Reply #6 on: January 31, 2011 - 07:20:20 PM »
I figure in a worse case senario if you have to fab one it may not be to bad. Lots of early model quicktime bells have that problem, thats why i picked up mine for $350 brand new. I will draw a sketch of what i have in mind for a possible fix, then do a quick mock up and see if it works out. If it does I'll be sure to let you know.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #7 on: January 31, 2011 - 08:23:33 PM »
here is a copy of my QT on my 6.1 I had to add a spacer for the starter to engage correctly.
Go Fast & Have Fun...
Offline punisher72
« Reply #8 on: February 03, 2011 - 01:00:08 AM »
Hey dodgeboy,are you running the 3/8 bolts that came with the housing? I ended up making 2 bushes out of ally to take up the size difference and using the 3/8 bolts. Haven't started it yet,but alignment appears good.  Fingers crossed :)...
    • THE DODGE BOYS
« Reply #9 on: February 03, 2011 - 06:13:42 AM »
Nop punisher72 7/16 top 3/8 bottom I like your idea may have to adapt it over.
Offline bigblue73
« Reply #10 on: February 08, 2011 - 09:07:23 AM »
Grade 8 (ARP) Shoulder Bolts - 7/16 body with a 3/8-16 thread.  Or you can drill the 3/8 thread out with a 3/8" drill bit and tap with the 7/16 thread.
Dodgeboys - Aren't you running an offset flywheel on your 6.1 install.  The new flywheels do not require a spacer of any type to line up.
Just a quick note, the starter cover is available from Quick Time if you are concerned over dirt migration.  Ross is the contact there and he's a quality guy to deal with.
Offline punisher72
« Reply #11 on: February 09, 2011 - 04:15:36 PM »
Well my motor is up an running and boy what a weapon! The starter works fine with the 2 3/8 bolts and ally bushes. If the motor comes out at some stage I might drill to suit larger bolts. The housing is a real quality unit and provides heaps of clearance all round. Btw QuickTime has been bought out by Prestolite now and Ross still runs his side of things. I'm very happy with how it all turned out and can't wait to go racing this weekend :)
Cheers guys
Pete
    • THE DODGE BOYS
« Reply #12 on: February 09, 2011 - 08:09:17 PM »
bigblue73
Nop didn't know they made an updated one :banghead: that would be nice, I may have to update in someday when its time for a new clutch.
Offline punisher72
« Reply #13 on: February 13, 2011 - 11:01:16 PM »
Had a great weekend of racing! Best time of 8:89 at 80 mph over the 1/8th mile. I was running 15/275/65 series street tyres and a 5400 rpm msd chip. No traction in 1st and 2nd. Wow it was fun  :bigsmile: :burnout:
Anyway i was having trouble with my clutch and it turned out all the geometry was wrong for the linkages and the pivot ball bracket on the housing was bending. :banghead:
Last minute fix before heading off racing. The bracket was removed and all braced up with another plate and 2 gussets.The zbar had the motor side linkage cut off and moved closer too the housing and had some extra holes drilled so we could fine tune it. Turned out 95% better but im told the best way is to run a hydraulic throw out bearing?
Has anybody ran 1 of these?
