Author Topic: Can I use a -73 door?  (Read 738 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
« on: January 30, 2011 - 10:35:21 AM »
Mine is a -70, what is the difference internally?
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Can I use a -73 door?
« Reply #1 on: January 30, 2011 - 10:49:55 AM »
I know the 73 door will be heavier due to re-enforcement to help with side crashes. I don't know if the window mechanisms will interchange or not. I believe they are different though.
Offline JayBee
« Reply #2 on: January 30, 2011 - 10:57:22 AM »
I used a '73 driver's door on my '70 and the body shop had no issues swapping out the internals into it, at least if they did they didn't tell me. I did however modify the screw holes for the weatherstripping to the "slots" so the '70 style can clip in. Just remembered, the  glass stops did mount differently but still work.
http://www.cuda-challenger.com/cc/index.php?topic=74104.msg753682#msg753682
« Last Edit: January 30, 2011 - 11:00:55 AM by JayBee »
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline femtnmax
« Reply #3 on: January 31, 2011 - 08:21:18 PM »
I just finished assembling my doors.  My 74 has one 73-74 door and one 71 door.  They both fit the car no problem.  The newer door is noticeably heavier due to extra reinforcement of the horizontal crash beam, they added a second outside layer to the entire width of the beam.  The door glass upstops are different, but also no problem if you stick with the upstop type that came with that year door.  If the 70 outside weatherstrip clips on, then maybe my older door is a 71 because both my doors have the screw on weatherstrip.  The forward vertical track for the door glass can be whatever year you have the parts for...I converted both my doors to the older "square block" style, only had to use matching track.  All the other parts can swap to any year door.  Hope this helps.
Phil
