Author Topic: valve cover breather  (Read 10087 times)
Offline Justins72
Re: valve cover breather
« Reply #15 on: February 07, 2011 - 11:10:52 PM »
Yea my valve covers don't have that hole for a Pcv valve.
Offline Aussie Challenger
« Reply #16 on: February 08, 2011 - 04:33:02 AM »
Strongly recommend that you have one installed and the breather too, motor will build up pressure inside and at best blow out a rocker cover gasket, at worse all the seals will start leaking.
Offline inviolet
« Reply #17 on: September 03, 2012 - 07:04:46 PM »
Don't want to Hijack the thread but interesting stuff,
Does it matter what side of the motor you put the PCV valve on? More often I see it on the drivers side.
Currently I'm running a 2 breather setup (one on each valve cover), with a draft tube on one of the breathers leading to the floor, but I'm think of going back to a PCV Valve setup due to strange oil leaks.
Original I ran a PCV valve setup but it failed (wimpy intake hose would crush under vacuum)and caused my valves to get gummed up.  Maybe a PCV with a catch can will be the best choice.
<<<<Old setup below>>>>
« Last Edit: September 03, 2012 - 07:09:33 PM by inviolet »
« Reply #18 on: September 04, 2012 - 08:15:29 AM »
Yes it matters, fit PCV onto the opposite side to the breather, that is breather on one R/C and PCV on the other R/C cover. Don't use heater hose or you will have the hose collapse on you.
« Reply #19 on: September 04, 2012 - 08:32:39 AM »
Does your valve covers have baffles? If not you will be sucking up lots of oil, fouling plugs and gumming up valves etc....?
Offline inviolet
« Reply #20 on: September 04, 2012 - 09:38:45 AM »
Yes the valve covers are baffled, but the baffles on aftermarket valve covers look wimpy, nothing like factory valve cover baffle.
Offline CUDA JAS
  • vroooooom!
« Reply #21 on: June 25, 2015 - 02:36:46 PM »
Hey, I know this is an old topic...but...If I did not have baffles in the valve covers, could that contribute to an overly smelly exhaust??
no mater whether I set my idle rich or lean (verified by an AFR meter) my car always seems to smell...
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline cudabob496
« Reply #22 on: June 25, 2015 - 03:42:36 PM »
I run my PCV hose first to a home made oil separator, then the carb.
Also, don't need 3/8 hose. I put a restriction in 3/8 hose
to make it a 3/16 hose, so won't suck as much oil.
2011 Kawasaki Z1000
« Reply #23 on: June 25, 2015 - 09:23:03 PM »
Jason
The baffles help keep out oil splash from entering the PVC valve, if your exhaust is smelly from oil burning it would also be black/brown from burning oil and the level would be going down also.
When my PVC wasn't working properly in my car a few years back I installed a piece of rod into the hose to block it having drilled a 1/16th hole which fixed the oil burning and didn't cause any gaskets or seals to leak from building up too much pressure.
Hope this helps.   :cheers:
   David
Offline Racer57
« Reply #24 on: June 25, 2015 - 09:56:17 PM »
Ok, I know its a dumb question,  but............  How does a hose running from the carb to the PVC on one valve cover have any effect with whats happening under the other valve cover ? Whats connecting them ?!?
Offline tman
« Reply #25 on: June 25, 2015 - 10:15:00 PM »
Think of a cross breeze.
« Reply #26 on: June 26, 2015 - 12:02:21 AM »
Excellent pic, inside the engine is a big hollow area.
Offline shadango
« Reply #27 on: March 01, 2017 - 11:03:18 AM »
Dredging up an old topic because I came across it and I have always wondered ----
I can see that if you have closed valve covers, with no breathers at all, then you could have the issue you talk about....blowing out gaskets.
But if you have a breather on one or both rockers, effectively venting them to air, wouldnt that eliminate any possibility of blowing out gaskets due to pruessure building up?  Even without the carb sucking in fumes, the pressure would not rise as it would escape through the breathers....
 :clueless:
From what I understood, PCV was mostly  an emissions change, keeping the vapors contained.
Offline usraptr
« Reply #28 on: March 01, 2017 - 02:39:04 PM »
I agree. On my new build 440/512 stroker I'm just running breathers on both aluminum valve covers.  So far no leaks but it is a new build.  I remember in the old days, (my dad's '58 chev) there was no such thing as PCV valves.  The crankcase was just vented via a metal tube at the back of the engine that went down towards the ground.
(Edited 8-1-17)
« Reply #29 on: March 01, 2017 - 03:25:02 PM »
Always heard oil leaks would be worse without a PCV ...Quick Google says it's so....
To simple not to have one IMO
https://www.cars.com/articles/when-should-you-replace-the-pcv-valve-1420680471182/
