dash cap
Author Topic: dash cap  (Read 5136 times)
Offline jackie
dash cap
« on: February 02, 2011 - 03:56:51 PM »
does anyone make a dash cap for a 1970 challenger? if not can you remove the pad without removing the dash?
1970 challenger r/t, prostreet 438 ci. 4 speed
Offline jackie
Re: dash cap
« Reply #2 on: February 03, 2011 - 07:29:39 AM »
how did it turn out?
Offline tomsa
    • My cars in swedish
Re: dash cap
« Reply #4 on: February 03, 2011 - 10:11:07 AM »
It looks fine to me.
Mine was missing the pressed down mark for the challenger logo at the passanger side :(
But it was for 1970 modell
About the sun I don´t have a clue because either the car or the dash have seen the sun yet :)
Offline 422STROKER
  • Member Since 6/3/06
Re: dash cap
« Reply #5 on: February 03, 2011 - 10:25:56 AM »
I've had mine on for a few years now, little warping around the defroster vents so far.  I got mine on ebay for like 90 bucks a few years ago.  Car sees regular use and plenty of sun.
Tom
Tom
Re: dash cap
« Reply #6 on: February 03, 2011 - 10:26:20 AM »
How do you like it? Any issues in the sun? I hear some have issues warping when they sit in the sun?
IMO they are junk. Mine looked decent when I first put it on, but after being in the sun a couple times it warped and split.
Offline jackie
Re: dash cap
« Reply #7 on: February 03, 2011 - 02:50:05 PM »
so this thing just gets glued on top for the old pad? has anyone put one with one speaker hole on top of a three speaker dash. i don't have a radio anyway. also can you remove the old cover without removing the dash?
Re: dash cap
« Reply #8 on: February 03, 2011 - 04:10:26 PM »
1. - Yes it gets glued on.
2. - When I bought my car it had a single speaker dash cap while the car came with 3 speakers up front.
3. - You glue the dash cap over the old dash pad, if that is what you're asking. I believe the best way to do this is remove the dash, or at least have the front window removed.
Offline ShelbyDogg
Re: dash cap
« Reply #9 on: February 03, 2011 - 11:49:48 PM »
Here are the hidden "nuts" to take off if trying to pull off the dash pad from the frame.
Don't for get the 2 visible screws  by the door and windshield pillar.
You can get to these by taking out the cluster and glove box liner
but it would be easier to take out the column and drop the dash out.
« Last Edit: February 04, 2011 - 11:13:24 AM by ShelbyDogg »
Offline jackie
Re: dash cap
« Reply #10 on: February 04, 2011 - 10:34:56 AM »
so it is easier to remove the whole dash? thanks for the pic's. do you also have info. on the bolts for the dash. thanks, jackie
Offline ShelbyDogg
Re: dash cap
« Reply #11 on: February 04, 2011 - 11:12:11 AM »
I find it easier to pull the whole dash out but there are lots of things to do before you can drop it out. A few things are dropping the column to the floor after taking out the seat, Unscrewing the bulkhead (fusebox and connectors) from the dash, and disconnecting any heater control cables and wires.
After loosening the 2 side nuts under the kick panels, the dash rotates down and out after taking out the 4 screws at rhe defroster vents.
I know MEK-Danger replaced his dash pad without pulling the dash out so he might want to say how hard or easy it was to do that. But for me, I can pull a column and dash out fairly quickly.
« Last Edit: February 04, 2011 - 11:15:57 AM by ShelbyDogg »
Re: dash cap
« Reply #12 on: February 04, 2011 - 12:40:31 PM »
It was no day at the beach, that's for sure. You need a short 3/8" wrench to get those 3 speednuts up by the windshield. It helps if you are a contortionist too.   :grinyes:
Offline IMNCARN82
  • LeDZeP
Re: dash cap
« Reply #13 on: February 04, 2011 - 12:48:49 PM »
I have a cap. Didn't bother glueing it.Once I saw the difference,Really wanted a new pad.There is no comparison IMO. Looks cheap because it is. I'm not saying caps can't be made to look/fit good.It is just a place I'd spend/save for a proper replacement.It's the dash...everyone looks at it.And you see it everytime you drive. Removing the dash isn't too hard,Just takes time. If you pull it,You might want to consider doing some other stuff too while it's out....
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Re: dash cap
« Reply #14 on: February 04, 2011 - 03:13:30 PM »
My big beef with having a cap was I hated the hard plastic feel of it. It didn't look bad though, so I can see going this way on a budget. I swapped mine out for a new pad. I'm glad I did.
