Author Topic: Plug Wire routing  (Read 742 times)
Offline Justins72
Plug Wire routing
« on: February 03, 2011 - 12:52:50 AM »
Not sure if this belongs in this section but I looking for pictures of how I can rout my plug wires on my 340 for a nice clean look with headers. Thanks
Offline 422STROKER
  • Member Since 6/3/06
Re: Plug Wire routing
« Reply #1 on: February 03, 2011 - 10:49:08 AM »
Are you looking for a fancy hold down system or what looks clean?
I used MSD pre-made wires on mine with some parts store separaters.
Tom
Tom
Offline Justins72
« Reply #2 on: February 03, 2011 - 11:18:53 AM »
looking for something fancy or clean just getting an Idea of how some people routed their plug wires before I start assembling mine.
Offline mr_340
« Reply #3 on: February 03, 2011 - 05:18:00 PM »
Tom,
 Where is you coil??? looks like I see the wire hanging. Did you use the stock location on the intake? just wondering if you did something diff. I have the M1 which has no provisions for a coil mount.
Justin,
A tip I recently heard was to use sb Ford wire set, it has 90* on the distributor end for a cleaner look.
Thanks, Gary
Offline 422STROKER
« Reply #4 on: February 03, 2011 - 05:34:29 PM »
Hey Mr.340
I mounted it vertically using the rear bolt hole, most aftermarket coils want to be mounted this way.
Tom
Just bent up a piece of metal in the vise and drilled a couple holes and rounded it off a bit.
Tom
