Author Topic: Flexplate removal  (Read 861 times)
Offline Moparinho
  • "Too many Ferrari and Lambo around me..."
Flexplate removal
« on: February 03, 2011 - 05:36:43 PM »
Hi,
can you please advice about safe removing the flexplate from the crankshaft.  I removed the 6 bolt and I can spin the flexplate around the crank but it doesn't pop off  :banghead: :banghead:   I want reuse the crank so I wouldn't make mistakes.
Paolo (Italy):
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383  (coming soon...)
'65 Shelby Cobra 427 Replica
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Flexplate removal
« Reply #1 on: February 03, 2011 - 05:51:41 PM »
it should come off easy,,you may need to pry it alittle,,even a large puller may help but I have never had that problem  with the flex plate that screw driver didnt cure with a little pressure to pop it off,,and if need be a little sanding around the outer edge before reinstalling
72rtchallenger
what happens in the garage
stays in the garage
Offline Moparinho
« Reply #2 on: February 04, 2011 - 07:18:52 AM »
the outer edge of the cranck seems to be a little bit deformed.  This should be the cause.  I was concerned to grind it off.  I wil try to post a picture.
Paolo (Italy):
Offline jimynick
« Reply #3 on: February 04, 2011 - 06:23:49 PM »
Unless there is a large deformation to the crank don't take a grinder to it. A flat, fine mill file should provide enough bite to clean up a burr. Obviously, keep the file as flat to the journal as possible and go easy. Hide the hammers from whoever worked on it last! :2cents:
  • 72 to 70 clone
    • cardomain
« Reply #4 on: February 04, 2011 - 08:01:36 PM »
72rtchallenger
stays in the garage
Offline Moparinho
« Reply #5 on: February 06, 2011 - 05:24:06 PM »
I had to use a puller to remove the flexplate. You can see the outer edge status in this pic.  Do you still think I just need to clean up the burr without a grinder  before resinstalling it ?
Paolo (Italy):
