who makes the best twin disk
Author Topic: who makes the best twin disk  (Read 876 times)
Offline RyanTurboTypeR
« on: February 04, 2011 - 03:31:47 AM »
i have a new 6.1 im about to put in my 70 challenger and im looking at doing a hemi 18 spline transmission or a passon 5 speed. I should be making around 700whp who makes the best twin disk for my set up?
Offline bigblue73
Re: who makes the best twin disk
« Reply #1 on: February 09, 2011 - 11:01:35 AM »
McLeod - Check out the RST Twin Disc.
http://www.mcleodracing.com/products/RST+Twin+Disc.mcl
Tony Edler
Hurst Driveline Conversions
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #2 on: February 09, 2011 - 08:11:12 PM »
My question is at what level should you step up and spend the extra coin?
Go Fast & Have Fun...
« Reply #3 on: February 13, 2011 - 11:01:20 PM »
I agree , McLeod makes awesome clutches
I would say in the 500-550 ft lb torque range , McLeod will be happy to elighten you on how much power the clutch will hold
Offline bigblue73
« Reply #4 on: February 15, 2011 - 12:57:39 PM »
The RST is good for 700.  The issue of stepping up in holding power is the elimination of the forgiveness.  Meaning the clutch becomes harsh and more prone to chatter.  Drag racing it doesn't matter as you want to transmit all the power rearward.  For the street it's a different story.  It all is what you want to deal with.  I have driven the RST clutch in a 500 horsepower LSX engine Camaro and the clutch is a amazing.  Smooth as silk and I have to say after seeing it at SEMA in '06, it;s a great combination of organic and composite material that really work.  Clutch pressure is still light enough that you can drive it (shifting) all day.
Other folks make twin discs so check them out, I can only recommend what I've driven.  Good luck.
