Author Topic: Dot 5 Brake Fluid  (Read 891 times)
Offline cwestra
Dot 5 Brake Fluid
« on: February 08, 2011 - 11:23:22 AM »
Can Dot 5 brake fluid be added to a system that already has some Dot 4 fluid in it, or does the entire system need to be flushed first?
Corey - in Northern Indiana
Re: Dot 5 Brake Fluid
« Reply #1 on: February 08, 2011 - 11:30:52 AM »
You have to flush the system first.
Offline Killer_Mopar
« Reply #2 on: February 08, 2011 - 09:33:04 PM »
 :iagree: Make sure you get every last drop because the two mix as well as oil and water. Also be aware of the drawbacks of DOT5 (aeration) before doing it.....with that said, I went DOT5 and havnt had any issues. I LOVE the fact that it isnt corrosive like DOT 3/4, which is the reason I made he switch (I had DOT4 eat the paint on my inner fender >:()
Offline JH27N0B
« Reply #3 on: February 08, 2011 - 10:06:19 PM »
It's an old wive's tale that you have to completely flush conventional brake fluid out of a system before putting DOT 5 silicon fluid in.  I used to be an engineer for Raybestos, and no one there ever said there would be an issue if there was a little Dot3/4 in the system when you added silicon fluid. In fact, I've generally used Dot 5 as assembly fluid when rebuilding master cylinders and wheel cylinders, regardless of whether the cylinder is going in a vehicle that uses conventional or silicon brake fluid.  Never had an issue, from a chemical standpoint, not sure how an issue could occur.  By far the biggest problem with brake systems is when the seals are exposed to anything petroleum based, EPDM and SBR rubber used in brake cylinders swells up and fails when exposed to petroleum based fluids, those compounds get along just fine with Dot 3/4 and silicon and mixing them doesn't alter anything (exceptions being Rolls Royces and light aircraft that use petroleum based brake fluid!)
When I've changed over fluids in a system, I open the bleeders and let the fluid run out while adding Dot 5 to the master cylinder.  I keep doing that until the fluid running out of the bleeders is purple.
Whatever you do, don't flush a brake system using alcohol.  That will damage the seals and cause problems! :2cents:
Offline CUDAchrisAUS
  • Valcoholic Petrosexual
« Reply #4 on: February 09, 2011 - 03:25:09 AM »
why not use DOT 5.1 that can be mixed without any problem with DOT 3/4 .
Its a full synthetic oil and non corrosive  :2thumbs:
« Reply #5 on: February 09, 2011 - 09:42:20 AM »
DOT 5.1 is corrosive to paint
Offline bordin34
« Reply #6 on: February 14, 2011 - 12:31:15 PM »
I thought it was law that anything DOT legal had to be able to mix.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
