Author Topic: engine mount ?  (Read 522 times)
Offline 70 RAG TOP
engine mount ?
« on: February 08, 2011 - 12:51:38 PM »
I finally got my engine installed but noticed one thing about the driver side engine mount.  The plate( with the locating pin) on the mount that connects to the bracket on the K member is not contacting all the way.  There is a small gap.  Right now the mounting bolt holes line up and the bolt is threaded in ok.  Is this normal or not?  If the gap was closed then the bolt holes probably would not line up.  The brackets on the engine are original, but I got the isolator part of the mount new from 440 source.  They seemed to match up ok to the old isolators.
Thanks
