ok, not a cuda or challenger, but as i posted before, i bought a 99 ram and have some questions. I was told that if the tranny is working fine at 122K miles, dont worry about changing the fluid and filter? any inputs?
Also, the shifter is a bit strange, to go into reverse, i have to put the shifter between P and R, to get into a forward gear, i have to pull it down to 2 and then once engaged, slide it to N to get it into what seems to be Drive. not sure if there is something wrong with just the cable or if there is an internal trans problem.
