Author Topic: Cost to install two new rear quarter panels?  (Read 11457 times)
Offline challngd73
« on: February 10, 2011 - 05:32:30 PM »
Just as it reads, anyone know?  Trunk is good, wheel tubs look good..need to replace the piece at the bottom of the rear window too.  Anyone have any idea an estimate of what a good shop would charge or anyone with experience on what it cost them?  thanks in advance.
Offline jimynick
Re: Cost to install two new rear quarter panels?
« Reply #1 on: February 10, 2011 - 09:58:23 PM »
In the "good" old days they used to pay approx. 14-16hrs per 1/4 and I'd guess about 4 for the upper body (dutchman) panel with the rear glass out for the 1/4's, flat rate. If it needs 1/4's, you can nearly bet it'll need trunk extensions, too. Figure $500 ea for AMD 1/4's and You'll have to look up the upper panel and extensions. Use your local rates- around here it runs $56-60/hr and none of this includes materials like bonding kits/seam sealers/rustproofing, etc. That'll give you a ball park, retail idea. Save your pennies! :22yikes:
Offline challngd73
« Reply #2 on: February 11, 2011 - 04:36:15 AM »
ha, i guess so! Thanks for responding.  now I can better plan my mods, to keep in my budget.  thank you sir.
Offline Final Challenge
« Reply #3 on: February 11, 2011 - 11:42:55 AM »
Carefull.  Many of us start out thinking that we just need this much work done.
There are many possible additional costs involved once you hand the car over to someone.
I had quotes of $7-50,000 for the same work, from reputable shops.
I finally realized, that I just needed a guy who is a bodyman and a mopar hobbiest, who wanted to help me on the project.
 His quote was $1800, and has grown to nearly $3,000 due to all the extras along the way.  The extras were truly necessary, to make me happy.  Paint will be extra, if I choose to have him do it.
The original work was to take about 7 full working days, since I already had the work started.  It has been 9 months now, and we have gotten very deep into rust issues, I didn't expect to see.
Offline cudagirl4406pk
  • Yes i am a Girl and No you cant drive my CUDA
    • Garageartmusclecars
« Reply #4 on: February 11, 2011 - 04:00:24 PM »
Well i know my husband charges $40 a hour and it takes time to make sure everything is right a good solid week of work to install rear 1/4's and you never know what is going to come up so be prepared and always have 20-30% more cash saved then estimate incase of troubles.
Yes i am a girl and no you cant drive my MOPAR :)
Offline challngd73
« Reply #5 on: February 11, 2011 - 04:46:38 PM »
yeah, i figured estimates would be all over the place..and I know the car is almost always in worse shape than it appears.  Im probably gonna have to bite the bullet while I have some "car" money, cuz if I dont, Ill use it on something else.  It looks ok now, and there are many go fast things i can get, but I would feel sooooo much better just knowing the rust is halted.
Offline Cuda Cody
  • Vancouver, WA
« Reply #6 on: February 11, 2011 - 06:32:59 PM »
Where are you located?  I might have the solution for you.
Offline challngd73
« Reply #7 on: February 11, 2011 - 06:45:52 PM »
upstate New York...about a half a world away from you!
« Reply #8 on: February 11, 2011 - 07:01:13 PM »
Take a look in the eastwood section under Final Challenge Progress, and follow the link.
240 plus pictures.  I needed a trunk floor, other than that the car looked good. I would have driven it for years they way it looked.
Offline femtnmax
« Reply #9 on: February 11, 2011 - 07:52:22 PM »
With the rear quarters and dutchman needing work, have you looked closely at the rest of the car...subframes, doors, trunk lid, etc.  What started on my challenger as 'rear qtrs' turned into much more...just as others have said on this post.
Phil
Offline challngd73
« Reply #10 on: February 11, 2011 - 08:48:44 PM »
I know the car needs more than just rear quarters, but I cant do a full on resto all at once, and I want to drive it and work on it little by little.  The floor boards and frame are in fine shape.  The fenders and engine compartment also look fine.  The door bottoms have some rust.  The dutchman has one small spot, and the quarters around the wheel wells.  Again, I cant do it all at once and I know rust is like an iceberg....far more than what you see on the surface..
Offline challngd73
« Reply #11 on: February 11, 2011 - 09:00:55 PM »
Absolutely impressive what you are doing by the way.  looks great.
Offline elitecustombody
  • Supra collector
« Reply #12 on: February 11, 2011 - 11:30:21 PM »
Be prepared to change outer wheelhouses and trunk floor drop-offs if there is rust around wheel wells .That is if you want to get rid og rust for sure. On average straight forward job it should take 50-60 hours to properly replace both quarters,outer wheelshouses,trunk drop-offs and dutchman panel,given there are no surprizes
Stefan B
Elite Custom Body = AMD Sheetmetal & Glass at great prices !!
Don't do what's easy, do what's right!!
