Author Topic: Eliminating ballast resistor  (Read 2402 times)
Offline priderocks
« on: February 10, 2011 - 08:39:46 PM »
This may have been discussed before, but I would like to eliminate the ballast resistor if possible, just to make the car a little more reliable. Do I just need a different coil to do this? If so, why didn't Mopar use a different coil in the first place?
Re: Eliminating ballast resistor
« Reply #1 on: February 10, 2011 - 09:14:41 PM »
One reason I went with an MSD 6AL box was to get rid of the ballast resistor.
« Reply #2 on: February 10, 2011 - 09:28:49 PM »
You need a different electronic ignition system. Keep the same coil. Mallory, MSD, etc you can do away with the resistor. The stock system needs the resistor to dissipate some power to preserve the coil/electronics. Newer designs use more efficient ways to control power than creating heat with a ceramic wire wound resistor.
Offline the_engineers
« Reply #3 on: February 10, 2011 - 10:03:48 PM »
Doesn't the HEI upgrade do this? Look for the $25 ignition upgrade thread.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #4 on: February 11, 2011 - 07:01:29 AM »
Yep    http://www.cuda-challenger.com/cc/index.php?topic=62561.0
« Reply #5 on: February 11, 2011 - 03:12:46 PM »
:iagree: Yup, there's lots of different ignition systems out there to choose from.
