noob question about filler and my round tail
Author Topic: noob question about filler and my round tail  (Read 604 times)
Offline 360FISH
  • BS23H3B567746
« on: February 12, 2011 - 08:35:43 PM »
Hi guys,
What is the right way to fix/patch this two inch gash?
I've never worked with fillers before.  Is this the place for a metal filler... bondo?
Any and all advice or links to good how to guides are welcome.
Thanks!
Alan
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline ted
  • 74 cuda, 70 challenger r/t
Re: noob question about filler and my round tail
« Reply #1 on: February 12, 2011 - 10:51:54 PM »
weld in new metal and finish  with filler
Offline jimynick
« Reply #2 on: February 12, 2011 - 11:38:36 PM »
There's more than one way to skin a cat, although the right way is what Ted say's- weld in new steel. BUT, you could also remove the t/lamp, clean the edges of the hole down to steel and use any one of a variety of fillers to bung it up. JB Weld is good stuff or short strand fibreglass (Tiger Hair) could be used, but you'd have to put in a backer to prevent fall-through and then be skilled enough to carve the majority of the filler out and re-configure the shape of the original panel; remembering that the inside has to be friendly to the t/lamp gasket to seal properly. If you're good with filling/sculpturing, go for it- otherwise get out the torches.  :2cents:
