Author Topic: 440 radiator  (Read 1554 times)
440 radiator
« on: February 14, 2011 - 09:43:45 PM »
Stock from the factory, BB with power steering. Did the lower rad hose go to the driver's side or the passenger side? I've been told that it should go to the driver's side. Mine goes to the pass. side but the motor is a '76. I also have power steering and it looks like it would be a tight fit to get a lower rad hose out that side.  :dunno:
Same question for the top rad hose. Looking at pics on the site it's a 50/50 split as far as I can tell. Did they come both ways from the factory? :dunno:
May be getting a new rad and was wondering where the outlet/inlet were 'supposed' to be.
Re: 440 radiator
« Reply #1 on: February 15, 2011 - 04:02:16 AM »
Mine has the top hose on the passenger's side and bottom on the driver's side. There were a few different radiators used back then, so maybe you can do a search on the part number to see the applications.
Offline RusTy/SE
  • Just havin' fun
Re: 440 radiator
« Reply #2 on: February 15, 2011 - 11:08:28 AM »
Regarding my original '956' radiator. My 1970 R/T SE came with ps, the A36 (3.55) Performance Axle Package (which added the factory cooler to the steering pump assembly).
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Re: 440 radiator
« Reply #3 on: February 15, 2011 - 09:44:05 PM »
You lower rad hose goes to the driver's side Rusty?
Offline RusTy/SE
  • Just havin' fun
Re: 440 radiator
« Reply #4 on: February 16, 2011 - 10:44:39 AM »
Yep, it does. It might have helped if I had answered your original question in my post :-[
Russ
2001 Durango     1B4HS
Re: 440 radiator
« Reply #5 on: February 16, 2011 - 11:37:11 AM »
 :thumbsup: Thanks!  :thumbsup:
Offline Roppa440
Re: 440 radiator
« Reply #6 on: February 16, 2011 - 11:40:19 AM »
Lower hose always on the drivers side on the E-body.
Top hose could be either side depending on engine size, HD options etc.
They cool better with the top hose on the passenger side.
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
Offline ShelbyDogg
Re: 440 radiator
« Reply #7 on: February 21, 2011 - 12:04:25 AM »
All of the 400s and late model 440s had the water pump inlet on the passenger side (lower hose).   Roppa440 is right about e-body big blocks. Lower hose is always on the driver's side.
Mine also that the A36 Hemi radiator. Top hose on the passenger side, with or without A/C.
