Author Topic: CAP auto strut bar question **TORQUE**  (Read 4100 times)
Offline shadango
« on: February 16, 2011 - 06:19:55 PM »
I cant find the email from a year agowhere Ray told me what the torque should be on the front mounting bolt and it is still not a shown anywhere in the online instructions.
(I would have thought the instructions would have been updated by now??)
I am pretty p*ssed right now....I had the info somewhere and now cant find it.
I am having an issue with the front connector rotating out of the 2 o'clock position to more of a 9/3 oclock position.
Anyone know of hand what the torque setting should be?
Offline Doomed
  • So close...to actually finishing my 'Cuda!
Re: CAP auto strut bar question **TORQUE**
« Reply #1 on: February 16, 2011 - 07:49:12 PM »
Here is Ray's personal e-mail:
raycostello@cogeco.ca
Kyle.
"Life gets in the way of Living"
Offline shadango
« Reply #2 on: February 16, 2011 - 11:22:58 PM »
Thanks Kyle.
Offline shadango
« Reply #3 on: February 21, 2011 - 09:06:43 AM »
Just for anyone else looking for this info, and for me another year from now when I need it again....LOL.....
The torque on the front bolt is supposed to be 42 ft/lbs wet, the rear nut 75 ft/lbs wet.
« Reply #4 on: February 21, 2011 - 03:33:18 PM »
Ok, what does 'wet' mean?
Offline Strawdawg
    • Vortex Buicks
« Reply #5 on: February 21, 2011 - 04:05:45 PM »
normally, it would mean with oil on the threads
Offline shadango
« Reply #6 on: February 21, 2011 - 05:16:58 PM »
Ray told me that in this case, "wet" means "with thread locker"....
« Reply #7 on: February 21, 2011 - 06:34:41 PM »
Oh, OK that makes sense. Just never heard of the term before.
« Reply #8 on: February 21, 2011 - 06:38:29 PM »
What about a lock nut? :dunno:
« Reply #9 on: February 21, 2011 - 07:59:03 PM »
That would be my preference, but would not look factory, which is important to some.
Offline shadango
« Reply #10 on: February 24, 2011 - 12:27:23 PM »
The part I am talking about is a bolt......the bolt itself sure doesnt seem like it is loosening up.....its almost like the joint itself is turning/cant grab the k-member enough to stay put.....    :dunno:
« Reply #11 on: February 24, 2011 - 12:38:51 PM »
Ah, So looking from the front of the K-frame you see a bolt, then a washer (of some sort), then going into the threaded body that the rod end is bolted to??
Offline shadango
« Reply #12 on: February 24, 2011 - 01:04:29 PM »
Yep......its a bolt, then an aluminum washer (thick) against the k member.....then, behind the k member, a chunk that the strut attaches to via a heim joint. The bolt threads into that chunk.
« Reply #13 on: February 25, 2011 - 09:57:26 PM »
Hummm that's what I thought? I don't see how that's ever gonna stay tight? Road/engine Vibrations, movement from suspension cycling etc....  This is one reason to mount it with rubber/urethane  IMO. Is there enough room to drill out the threads to put the bolt through from the other side and use a lock nut and bolt? Fine thread is stronger too.
Offline drewcrane
« Reply #14 on: February 25, 2011 - 11:39:09 PM »
Well I would like to know and clarify , I have the same and now I am wondering, lock washer? lock nut? nylock?
