Author Topic: Front headlights- electrical problem?  (Read 765 times)
Offline 72Chall77Doba
  • Bill's Mopars
    • My Car Domain Page
« on: February 17, 2011 - 12:33:54 AM »
On my 72 chally, when I turn on the lights the outer two headlights go on.
When I step on the high beam button, only 1 outer headlamp goes on and
on the opposite side only 1 inner (high beam) goes on,
the outer one goes off.
Any suggestions.
Thanks
Offline UKcuda
  • Tell them I'm on my way
Re: Front headlights- electrical problem?
« Reply #1 on: February 17, 2011 - 04:56:06 AM »
Any suggestions.
Thanks
Either you have a burned out filament in one outer and one inner lamp or you have a bad connection on the same.
'72 'cuda
« Reply #2 on: February 17, 2011 - 06:51:34 PM »
Change the low beam that goes out on high and change the high that never comes on.
Offline 73EStroker
« Reply #3 on: March 02, 2011 - 01:58:42 PM »
That sounds like a ground issue. Locate the headlight harness ground, clean the connection and reinstall using vaseline or grease on the connections. Most funky problems like these where one day something was working and the next it doesn't, usually results in a faulty or bad ground connection.
Barry (Salmon Arm)
