Author Topic: steering column reassembly frustration  (Read 584 times)
Offline 7samurai
« on: February 20, 2011 - 01:22:42 AM »
when I try to attach the shift plate and lock plate to the column with the 4 screws, it does not align properly.  It was fine before I took it apart, but when I try to reattach it, the ignition plate will not align with the shift (lock) plate. I know on the floor shift, there is not a washer between the shift plate and the column, so I have no idea what to do now.  when I tighten the screws, the spacing between the lock plate and the shift plate gets skewed.  Tried this several times.  HELP!
Offline Barracudadan
Re: steering column reassembly frustration
« Reply #1 on: February 20, 2011 - 09:41:15 PM »
Maybe this can help you out it`s a pdf. file that someone here sent me awhile back.It is a very detailed disassembly and re-assembly of a steering column.Send me an E-mail or Pm and I will forward you the file.
« Reply #2 on: February 21, 2011 - 03:28:41 PM »
Maybe a pic to go along with the explanation?
