Author Topic: Miller 211 welder Wiring Question  (Read 1514 times)
Offline daveh
« on: February 20, 2011 - 10:34:38 AM »
Hey guys I installing the 220V outlet for my Miller 211 welder.  I'm fairly certain that I should use 10/2 wire.  Am I good to go with that?  Thanks
Re: Miller 211 welder Wiring Question
« Reply #1 on: February 20, 2011 - 11:26:07 AM »
#10 is good for 30amps. If you look at the plug attached to the welder it will have an amperage rating or check the manual and see what it requires for input current(not welding amps). Then size the wire accordingly.
Offline 72cudamaan
« Reply #2 on: February 20, 2011 - 12:01:13 PM »
   :iagree:  But I might also suggest going to the next larger gauge wire if you plan on using a long cord. I made my cord 35 ft. long so I can roll my welder out of the shop and use it in the driveway if I need to.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Challenger III
« Reply #3 on: February 20, 2011 - 12:59:04 PM »
Make sure you use three conductors! Some think the grounding conductor isn't important, but it sure is!
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #4 on: February 20, 2011 - 01:00:50 PM »
72rtchallenger
what happens in the garage
stays in the garage
Offline daveh
« Reply #5 on: February 20, 2011 - 02:51:00 PM »
Thanks guys.  It's only wired 4 feet from the box in the garage, so I should be good.  Thanks for the confirmation.
Offline the_engineers
« Reply #6 on: February 20, 2011 - 04:41:53 PM »
Looks like Miller says it's 25A, so you're in the clear!
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #7 on: February 20, 2011 - 05:19:44 PM »
Good idea! :2thumbs:
« Reply #8 on: February 20, 2011 - 07:15:08 PM »
Just nitpicking, but... the ground is not referred to as a conductor. If you buy 14/2 cable, it will have 2 conductors and a ground for a total of three wires.
But I agree, the ground wire is THE MOST IMPORTANT connection you make. It is the one that can/will save your life in the case of an electrical fault.
