Author Topic: 360 Head and Cam choices for my Challenger  (Read 9038 times)
Offline Aussie Challenger
Re: 360 Head and Cam choices for my Challenger
« Reply #15 on: February 27, 2011 - 06:36:43 PM »
Is the RHS 67cc combustion chamber the old open chamber style with NO quench built into the combustion chamber??
No it appears to be the later style Magnum.
Offline cudazappa
« Reply #16 on: March 01, 2011 - 06:15:11 AM »
Well, I called Hughes yesterday.
Guy was really helpful, basically said the KB107s were too high a compression for what I wanted.
His recommendation was to run their HUG 2022 piston (is this the same as the KB262?).
Also recommended a .054 gasket and my stock heads with the sportsman valve/porting job. I forget the cam specs, so I'd have to call them again.
Uncle Sam sent me my money so I got some purchasing to do!!!
2015 Dart GT - Daily Driver
Offline femtnmax
« Reply #17 on: March 01, 2011 - 02:03:41 PM »
Hughes is making sure you don't get any quench benefit from the piston dome.  They are milling the head down to 62cc (spec is 65-72??), then they are sticking in a thick head gasket (.054).
Why not less milling on the heads to preserve head gasket sealing surface strength, and run a thinner head gasket?  Even the Hughes ad says they are using a 0.039 head gasket with the pistons they recommended to you.
Feed the Hughes numbers into KB calculator:
Result is 9:1 static and 7.5 dynamic.  Pretty conservative for cast iron heads.  Are you planning on regular grade fuel?
head volume  62cc
piston volume 19.4cc
gasket thickness  0.054 inch
gasket bore 4.08
cylinder bore diameter 4.03
deck clearance 0
stroke 3.58
rod length 6.123
intake closing 60*abc
My old work truck is running 9.6:1 compression with iron heads, 0.045 quench, and can pull a 8k lb trailer weight up any hill without knocking....all with the cheapest regular gas from the pump.
Maybe go over the Hughes info with your engine building buddies...
Here is another option using the KB flat top pistons you already have, and your cast iron oem heads:
Result is 10:1 static and 8:1 dynamic; better than the Hughes example IMO.  Would need premium fuel, but also leaves you open to aluminum heads in the future.
cast iron head volume  65cc
piston volume 7cc
gasket thickness  0.04 inch
gasket bore 4.08
deck clearance 0.01  (below deck)
stroke 3.58
rod length 6.123
intake closing 64*abc
OR...change the KB flat top example above by increasing the cast iron head combustion chamber volume to 67cc, and close the intake valve sooner at 62* abc; result is even more streetable at 9.8:1 static compression and 8:1 dynamic.
HOw to increase combustion chamber volume...simply unshroud the valves for better port breathing can give the 5cc increase.  OR...let the piston be a little lower below block deck at TDC, rather than the 0.01 number I used.
Just some ideas.
« Last Edit: March 02, 2011 - 09:24:23 PM by femtnmax »
Phil
« Reply #18 on: March 02, 2011 - 05:23:16 AM »
RHS claim their combustion chamber volume is 62cc out of the box.   :bigsmile:
Offline jimynick
« Reply #19 on: March 02, 2011 - 11:33:14 PM »
Phil is right about the loss of quench once you're over approx..040" piston to head clearance. It'll actually INCREASE the chance of detonation in the perverse way it works. He gave you some pretty good recommendations, but you can call Comp Cams help line and they'll go over it with you as well as make some cam recommendations. Good luck!
« Reply #20 on: March 06, 2011 - 12:54:52 AM »
Pewrsonally I would call Lunati & get a Mopaer grind cam not the clone chev comp grind
