Author Topic: 72 Rad and Shroud question  (Read 826 times)
Offline bandt
« on: February 20, 2011 - 07:27:33 PM »
Hi Guys,
Hoping someone can enlighten me,
I have a 72 Challenger with a 340 has the correct 22" rad # 3574628. Car didn't have a shroud when I got it. I bought one part # 2998328. Researched both #'s and they seem to be correct. It has a stock viscous clutch fan. The shroud doesn't fit, not even close. Needs to come up and to the right. My thought is the rad brackets that hold the fan shroud maybe incorrect, but they appear to have been on the rad forever. I'm at a loss, can someone help.
Thanks,
Brian
Offline bandt
Re: 72 Rad and Shroud question
« Reply #1 on: February 20, 2011 - 08:49:15 PM »
Thought of something else, the car was originally a 318. Not sure but are the motor mounts and K-member brackets different for a 318? 318 k-member not the same?
Offline v21jeff
« Reply #2 on: May 21, 2013 - 01:57:19 PM »
Hey Brian. Did you find an answer? It sounds like the same issue I'm having. Jeff
Offline blown motor
« Reply #3 on: May 21, 2013 - 04:09:14 PM »
Sometimes things aren't what they seem. I have a 74 Challenger with a 340, originally a 318 car. I needed a new fan shroud but the 74s were a one year item, different from the 70-73 models and noone made a reproduction shroud. Turns out I needed a 70-73 shroud as a PO had changed the rad at some point. Make sure your rad is what you think it is.
Offline EMCD
« Reply #4 on: May 21, 2013 - 04:23:18 PM »
I have a 1972, 22" original radiator and shroud from my Cuda 340 that I'm thinking about selling. Let me know if you are interested.
Offline v21jeff
« Reply #5 on: May 22, 2013 - 09:48:50 PM »
Thay would have probably saved me a lot of trouble. Is it part # 3574628? I think I need to try to make this one work. I have like $500 invested into it now. Could I bother you to measure the studs where the shroud mounts. Maybe this will help me understand what is going on. Thanks, Jeff
Offline cudabob496
« Reply #6 on: May 22, 2013 - 11:41:12 PM »
Radiators and shrouds are really easy to re-position. For my shroud, I re-positioned it
by buying some 3/16 x 3/4 x 48 inch aluminum from Home Depot, cut and bent some lengths
to the desirable shape, then drill holes at each end for the bolts.
2011 Kawasaki Z1000
