Author Topic: e body fan switch help needed  (Read 3219 times)
Offline 572b1cuda
« on: February 20, 2011 - 10:02:31 PM »
this one may be a stretch but i hope someone can help. a previous owner removed the fan switch in my 71 barracuda ( standard gauges),i wound up have 2 complete bezels with all the switches. one says (cool  temp  warm) on the temp switch and the other just says warmer with an arrow pointing to the right and thats the same one in my 71. so i took the switch out of that one but the problem is i only found 3 wires (that were cut and capped :pullinghair:)one light green ,one dark green and a black with white stripe, but the switch out of the same bezel as mine has a 4 pin fan switch , the other one has a 3 pin fan switch but its from a different year (i think 74). i guess i have to use the 3 pin switch since there are only 3 wires right? if so i am not sure where which color goes since the plug/plugs were cut off. i am going to post a few pics of the switches. any help would be great. thanks c/c
Offline 572b1cuda
Re: e body fan switch help needed
« Reply #1 on: February 20, 2011 - 10:06:41 PM »
here is a pic.
Offline 572b1cuda
« Reply #2 on: February 20, 2011 - 10:09:57 PM »
question, is there a 2 and  3 speed fan motor?  the 4 pin seems to have an extra click.sorry this pic stinks!
« Last Edit: February 20, 2011 - 11:28:10 PM by 572b1cuda »
Offline ShelbyDogg
« Reply #3 on: February 20, 2011 - 11:30:15 PM »
Use the 3 pin switch , like you said.  Here is a pic from the back.
Offline 572b1cuda
« Reply #4 on: February 21, 2011 - 12:08:14 AM »
shelby you are the man!!!! i owe you one.
Offline 572b1cuda
« Reply #5 on: February 21, 2011 - 12:11:09 AM »
btw, how did you get the pic, did you just reach up there with your camera and take a pic?
Offline ShelbyDogg
« Reply #6 on: February 21, 2011 - 10:12:54 AM »
My dashboard is fully mocked up on a wooded stand with a complete wiring harness with tail lights and power window motors. Spare ignition and turn signal switches are also plugged in.  12v is supplied by a power supply and lets me test all of my lights, radio, etc.     I just tested my wiper motor yesterday before installing it in my car for the final time.
You can see it on page 10 of my resto thread at the bottom.
http://www.cuda-challenger.com/cc/index.php?topic=44869.135
Offline 572b1cuda
« Reply #7 on: February 22, 2011 - 08:00:03 PM »
very cool, i am going to check out your resto thread. i have another situation ,i was getting ready to install the ac heater box and found this little rubber (plug/vent?) in the box and cant figure out where it goes. there is an extra hole on the firewall next to the lower box drain holes but there are no screw holes in the firewall. i am pretty sure one side of the vacuum line goes to the box, but not sure where the other side goes to. i am going to post a pic.
Offline 572b1cuda
« Reply #8 on: February 22, 2011 - 08:01:28 PM »
other side.
this is what i hate buying a car that someone else took apart!
Offline ShelbyDogg
« Reply #9 on: February 22, 2011 - 09:27:42 PM »
Don't know what yours is from because my 3 look like this:
Offline 572b1cuda
« Reply #10 on: February 22, 2011 - 10:05:26 PM »
i am not sure what mine is from either, it was laying inside the heater box. but if i cant find the right one i can probably make it work.where does the vac line the comes out into the engine bay go to?
Offline ShelbyDogg
« Reply #11 on: February 22, 2011 - 11:16:32 PM »
The hose goes to the vacuum fitting on the manifold.
Offline 572b1cuda
« Reply #12 on: February 23, 2011 - 11:42:04 AM »
thanks again shelby :cheers:. i am pretty sure my car had the same firewall plug as your because there are no screw holes and i can see where it was on the firewall. maybe the one i have is from a later year. any idea where i can get the right one or what its called?
Offline ShelbyDogg
« Reply #13 on: February 23, 2011 - 11:50:09 AM »
Until you find one at a swap meet or someone starts making them, I would use a floor plug of the same size and just stick a vaccum hose through it.    The factory rubber plug had that hose molded into it.
You could also try to make one (close enough)  starting with a big rubber stopper from a glass container from a company lab.  Drill a hole for the hose the use a grinder to finish the shape and lip to keep it in the metal.
