Author Topic: Correct pinion angle and how to read it  (Read 17655 times)
Offline shadango
Re: Correct pinion angle and how to read it
« Reply #30 on: February 25, 2011 - 02:41:29 PM »
As far as shims go, they normally fit between the spring perch on the axle and the top leaf.  You only want to rotate the axle x degrees, not any of the springs.  The spring pack (including add a leafs) should remain together.  The tension and spacing of the U-bolts will keep them in place.   Depending on the thickness of the add a leaf and shim you may need longer U-bolts, so take some measurements before cutting stuff up.
Here is how the add-a-leafs have my car sitting....
So you are saying  you do NOT need to pull the spring pack bolt out?
Thats fine with me, if it works.....but I have read elsewhere (4x4 forums mostly) where people say you do have to pull the bolt out, add the shim, then bolt it back together.....of course, in that situation they are talking about axle-under-spring setups.....our cars have axle-over setups.  Plus, wouldn't that also mean I need to know the size of the head on the locating bolt and the size of the hole in the shim itself?
Seems like running teh bolt thru the pack and the shim, then bolting together would be "safer"....?
Offline Jesus H Chrysler
« Reply #31 on: February 25, 2011 - 03:54:47 PM »
Your car looks like it's sitting a little high in the back.  I'm assuming that's the look you're going for.
I would research the installation of the shims you're looking for.  Thru bolting the shim in place would seem safer, but if the instructions say no, then follow them.  The Jeep Wrangler YJ series has spring under design just like RWD Mopars.  The shims function exactly the same.  The shims I used slipped on top of the locator bolt to hold them in place while you bolted the spring to the axle.  The locator bolt kept them from getting "spit out".  If you changed your locator bolt to some other design due to the add a leaf then you may need to investigate another option.  The U-bolts keep the shim from spinning around the locator bolt and coming out the side.
So to understand your setup, what kind of springs did you use before the add a leafs?  I put XHD springs in the rear and still had to put air shocks to get my car to stop sagging and sit level.  I have a pair of used SS springs that are going in this year just to see if I can get rid of the air shocks.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline shadango
« Reply #32 on: February 25, 2011 - 05:36:12 PM »
I had stock springs in the car, which were soft and, in my eyes, saggy.   With anyone besides me in the car it bottomed out on bumps etc....stuff banging around under it....and that was just two small kids in the back.
Looking into spring choices, seemed like the ready-made options would not be much better, or just give me  a stock (low) look......I wanted the car to have a little rake.....I had read that super stock springs actually make the car sit crooked in back as one is stiffer than the other to counteract launches.  I read here as well that you could have custom springs bent but that sometimes it is a crapshoot.
So, not sure what springs to get at the time, I lived with it for the first summer I had the car.   Then that winter I decided to follow the lead of another member here and try the add-a-leafs temporarily.  For $80 or so it was a cheap gamble.  I removed the half-leaves and replaced them with the add-a-leafs.  Replaced the pack bolt with the new one at that time as well as new u bolts.
(it was just last winter that I did that and I just cannot remember how the pack bolts works in relation to the plate etc....hence my questions.)
Lets just say the add-a-leafs took care of any sag or bottoming out. LOL....I also added 1" torsion bars up front.  The thing handles like its on rails as long as I dont push the speed TOO hard in corners, cause then the rake comes into play.  But its not a rally car anyways...its a cruiser/funmobile.
It rides firm, but not like a dump truck.   I actually like it.  That, and I have lower profile tires on it than I would like....going to a bit taller ones soon I hope.  Also have KYB shocks all around (had to go with dodge pickup shocks in the back for the extra length).
I compared my car to a guy's 72 'Cuda down the street...he has super stock springs on his.  My bumper sits a couple inches higher than his.
I think i might eventually go with springs that drop her down just a tad IF I can figure out what to get.... but for now it works for me...I like some rake.....and I have gotten great feedback at car cruises etc....LOL  ...I want to wait til I get new tires and rims so I can see where I am at......the shims are just to correct the issues right now and hold me over.
« Last Edit: February 25, 2011 - 05:43:41 PM by shadango »
