Author Topic: Manual vs auto accelerator pedal  (Read 1401 times)
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« on: February 21, 2011 - 03:56:46 PM »
Are the accelerator pedals different from manual and automatic trans?
I am install the new hump for the manual trans and my accelerator pedal seems real close.
Jackson from Toronto.
Re: Manual vs auto accelerator pedal
« Reply #1 on: February 21, 2011 - 06:42:38 PM »
I agree...it's close. But I don't think they are different.  :2cents:
Offline vinb
« Reply #2 on: February 22, 2011 - 11:08:27 AM »
I think they are the same too, but after you get it in place just mark it and with a little heat hammer & dolly it for a little more clearance..
You don't have to go that much.....
« Last Edit: February 22, 2011 - 04:49:56 PM by vinb »
Offline boydsdodge
    • Boydsdodge
« Reply #3 on: February 22, 2011 - 09:30:45 PM »
Cool guys, thanks.
Offline the_engineers
« Reply #4 on: February 22, 2011 - 09:50:01 PM »
I put sound deadener under my carpet...made it that much worse. I'll have to dent it too, now.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #5 on: February 22, 2011 - 10:03:10 PM »
What about bending the rod the pedal attaches to? Or slotting some holes? Or would it be to close to the brake pedal? :dunno:
Offline Challenger III
« Reply #6 on: February 22, 2011 - 10:23:34 PM »
I have been through this before. I heated and bent the gas pedal rod over, then heated & bent it again closer to the pedal to make the pedal back to the original angle. This put the pedal higher, so I added a piece of round rod to lower it.  :lol: Turned out nice, but it was more work. I think manual cars had a different piece. I'll probably do the same this time as I did before.  :banghead:
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline boydsdodge
    • Boydsdodge
« Reply #7 on: February 24, 2011 - 08:25:32 PM »
Thanks guys, Brad Challenger I was just going to do the bend when I thought I'd ask if there was a different piece.
Thanks  again all.
Offline Challenger6pak
« Reply #8 on: February 24, 2011 - 10:25:28 PM »
Both the manual and the auto trans used the same accelerator pedal.  There is only one part number for both transmissions.  Things just get close when they put three pedals under the dash.
