Author Topic: Isky Rocker arms  (Read 1114 times)
Offline theblurr
Isky Rocker arms
« on: February 23, 2011 - 11:22:02 PM »
Have any of you had any problems with isky 1.5 rocker arms, I have a set I was going to use own my sons 440, But after I talked to Dave at Hughes I'm not sure about using them, He said that they used to sell them but customers had experienced problems with the rockers wearing on the shafts, He said it was a iron rocker on a iron shaft issue that caused them to wear. Thanks Brent
'I will live until I die,
Then I will live forever.'
                    Brent
Offline oldkimmer
Re: Isky Rocker arms
« Reply #1 on: March 02, 2011 - 01:14:14 AM »
....They have been the old stand buy for many years, ofcourse spring rates and ramps are different now adays....i still use them on both flat tappets.....kim..........
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline theblurr
« Reply #2 on: March 03, 2011 - 10:39:34 PM »
Thanks Kim for the reassurance, I going to use them on a lunati hyd. flat tappet .513 lift. Brent
                    Brent
« Reply #3 on: March 06, 2011 - 01:08:29 AM »
you should have no issue , the spring load with the hyd cam is relatively light Crane had a similar product & I used those a lot
Offline theblurr
« Reply #4 on: March 07, 2011 - 09:36:43 PM »
Thanks Chryco!
                    Brent
