EFI install observation: FAST vs Edlebrock 2 Pro Flo 3550
Author Topic: EFI install observation: FAST vs Edlebrock 2 Pro Flo 3550  (Read 12179 times)
Offline ajantics
    • Yeah......Im a drummer!
Re: EFI install observation: FAST vs Edlebrock 2 Pro Flo 3550
« Reply #15 on: February 16, 2012 - 12:12:24 PM »
just a quick question,what about if your running a shaker hood?i have a big block 440 and was putting a shaker hood on it.will all these system still work?
     I’m running a 727, and the stick kickdown fit right on.  Hood clearance is NOT an issue as the system is the same height as a 4150.  I’m running my 4 barrel shaker with no mods or problems
The fast ez efi system  fit on my hemi dual quad shaker too! The throttle bodies in this kit are the same size as any other 4150 carb. I can not speak for any of the other efi systems on if they fit a shaker. :thumbsup:
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Offline ragtopdodge
« Reply #16 on: February 16, 2012 - 06:29:36 PM »
Fitting a SHaker w/any aftermarket intake will be a challenge unless it's a stock height dual-plane low rise Performer or Action.
If you want a better intake, then I'd go w/a Victor or some single-plane high-rise and go w/the a throttle body and injectors bungs/fuel rails.
http://www.summitracing.com/parts/EDL-29545
Some neat ideas:  http://www.fastmanefi.com/photos.htm
« Last Edit: February 16, 2012 - 06:39:59 PM by ragtopchally »
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #17 on: February 16, 2012 - 06:37:39 PM »
FYI
I asked an e-bay seller about the height of the "dry" ( that's what I'll call it?) throttle body and he said 2 1/4" ?
I then measured my Holley 750 I have laying around and it is 3 1/4"   STR intake is aproximatly 2" taller than the Holley street dominator so I still have to "find" about an inch..... :working:
« Last Edit: February 16, 2012 - 06:45:18 PM by brads70 »
« Reply #18 on: February 17, 2012 - 08:40:38 AM »
the accufab T body is the shortest one I was able to locate @ under 2"
« Reply #19 on: February 17, 2012 - 08:45:56 AM »
Ya I think with that TB and the road runner 440 base it should all fit with the STR intake. It just won't seal up to the bottom of the hood. Not a big deal to me.
