Author Topic: Third member problem?  (Read 961 times)
Offline cudadave72
  • you motorboatin sob!!!
« on: February 24, 2011 - 07:47:12 PM »
I sold my 8 3/4 center section to another c-c member here. While it was in my car I never had one once of trouble out of it and it performed perfectly. Once reinstalled in his car his tells me it is making tons of accel and decel noise to the point it resonates in his car. I'm not doubting him but what could have happened?? It was shipped cross country and I was wondering if it could have been dropped as I insured it. Any other thoughts?
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline ireland383
Re: Third member problem?
« Reply #1 on: February 26, 2011 - 06:53:33 AM »
His pinion angle could be different then yours.  :dunno:
1971 Plymouth Barracuda
Offline Challenger6pak
« Reply #2 on: February 26, 2011 - 08:14:21 AM »
Is it a sure grip?  If so did he just use differential fluid or did he use differential fluid and the friction modifier.  I don't know if it makes a difference in sound; but it may.
« Last Edit: February 28, 2011 - 09:10:21 PM by Challenger6pak »
Offline cudadave72
« Reply #3 on: February 26, 2011 - 09:49:14 AM »
Both good points and I will ask him this. It is a sure grip. The good news is that his gear guy checked it out and said the pattern was good so it cant be too bad. He also said the pinion nut was a little loose and that one of the u bolt straps was a little bent which could indicate it was dropped in shipping. Hopefully retorquing the pinion nut will solve the issue.
« Reply #4 on: February 26, 2011 - 12:18:58 PM »
Make sure he knows to run the friction modifier or additive. Many people don't know to run it or forget to run it.
Offline SBDave
« Reply #5 on: February 28, 2011 - 08:41:20 PM »
I second that friction additive for the sure grip.  Went for a ride in a friends car who forgot to add it and we chased down the noise for a while.  It ended up being that additive.  I'm betting it's the same case with yours.
