Author Topic: 71 Cuda Pro-Touring Build  (Read 194207 times)
Offline GranCuda1970
Re: 71 Cuda Pro-Touring Build
« Reply #105 on: September 28, 2011 - 11:34:26 AM »
The wheels look great also!! :grinyes:
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #106 on: September 28, 2011 - 06:50:33 PM »
Thanks Guys, The wheels and tires were actually a good deal , I know they are Mustang Bullet rims but the backspace and widths were almost perfect. http://www.americanmuscle.com/blackwheels.html
« Last Edit: September 29, 2011 - 06:08:55 PM by johns cuda shop »
Re: 71 Cuda Pro-Touring Build Gen III Aluminum 426 hemi T56 6 speed
« Reply #107 on: October 02, 2011 - 03:31:25 PM »
After some careful measuring , I deleted the bumper gaurd valance provisions. (i won't be running bumper guards) I used some 18 ga sheetmetal and flanged them 3/4 to the panel.I made sure that tack welded the new patches in while bolted to the car (this way the valance stays inline with the rest of the body). I then tig welded them so I can easily hammer and dolly any minor warpage that might be created when welding the new metall. It now only needs minor filler to be straight. It looks much cleaner now without the holes.
« Last Edit: October 02, 2011 - 08:56:58 PM by johns cuda shop »
Offline dutch
« Reply #108 on: October 02, 2011 - 04:56:06 PM »
very nice  :wow:  I like the looks of that.
This trick will get you in trouble when using leaf springs huh...?
*** Bart ***
Offline BB 70 Challenger
    • Restored Sports Cars
« Reply #109 on: October 03, 2011 - 05:14:25 AM »
So true. If using stock type leaf springs, yes, that welding trick is sure to get you in trouble.
And if building a rear suspension something like the link below, then all that welding starts to make very much sense?
http://s1187.photobucket.com/albums/z400/customachinecomponents/71%20Cuda%20Pro-Touring%20Build/?action=view&current=100_2046.jpg
« Reply #110 on: October 03, 2011 - 07:34:04 PM »
  :poopoke:  I have a RMS triangulated 4 link .Yes, If you have a leaf spring rear the shackles would hit the valance   :roflsmiley:
« Last Edit: October 04, 2011 - 04:07:37 PM by johns cuda shop »
« Reply #111 on: October 06, 2011 - 05:11:32 PM »
I spent a day media blasting inside and out the fenders, header panel, dash cage and rear valance. Epoxy primer followed after that. No real suprises, just some minor work was hiding under the paint.
Offline blackcuda69
« Reply #112 on: October 06, 2011 - 05:57:16 PM »
no fender gills???
« Reply #113 on: October 06, 2011 - 07:33:11 PM »
I installed a set of fender gill patches today. After getting the correct location and fitting them to size ,I created a 1/2 flange all the way the patch panel. I used SEM panel adhesive ,this way it will elinminate any warpage caused by welding and also keeps the dreaded mig weld  (hard weld ) to bleed through the paint on hot sunny day with dark colors
Offline NHawkins
« Reply #114 on: October 07, 2011 - 09:23:50 AM »
This car will be a stud.  And this obviously isn't your first rodeo with fab work; impressive.
Just curious... being from MB, SC, are you familiar with the Classic Car Musuem in the area?  It isn't advertised as a Mopar exhibit, but out of the 40 vehicles on show, about 35 of them were 1967-1970 Mopars.  (1 owner who is now displaying his collection.  90% are former drag cars that are original and unrestored!... While on the tour, a visitor asked the owner why he had "so many Dodges and only 1 Mustang?!?"  The owner smiled and calmly responded... "Well, I liked winning".)
Best of luck as you keep building your E-body!  I enjoy watching the progress!
« Reply #115 on: October 09, 2011 - 03:07:26 PM »
Yes, The Antique car museum is 90% mopars. The owner of the museum Paul ,has about 50 cars there at the Myrtle Beach site but don't let him fool you he has close to 200 mopars!! Thank you for your great comments on the Cuda are greatly appreciated. More to come. :bigsmile:
Offline TROUBLE987
« Reply #116 on: October 09, 2011 - 06:15:18 PM »
I'm in MB once a year I'm going to check it out..thx
« Reply #117 on: October 09, 2011 - 07:25:32 PM »
Here is the link to the museum   http://www.wheelsofyesteryearmb.com/     :wavingflag:
Offline PowerD
« Reply #118 on: October 10, 2011 - 12:05:35 PM »
I go there 2-3 times a year just to figure out how to put the gtx back together. The guys that run it are real nice, and boy do they have some sweet cars. Of course the hemi cars are great but one of my favorites there is that black 72 340 cuda with the shaker hood.
« Reply #119 on: October 11, 2011 - 07:29:54 PM »
With the hydraulic clutch master cylinder being fully bottomed out when I depress the clutch, I decided to make a ajustable stop for the clutch pedal. The pedal rod in the kit was too short, I made it 1 inch longer. This way the clutch pedal sits in the full up postition. Some other items done today was making a shifter bracket that angles the pistol grip back 20% and moves it back 1 inch,. The shifter feels much better now. I will have to move the shifter boot and bezel back another inch also. Made a few more brackets for the vintage air and some windshield frame gussets.
