I decided to get rid of the sloppy trunk torsion rod and convert to gas cylinder lift. After calulating the weight of the trunk lid , purchased 2 gas cylinders. I mounted it on the steel hinges first to establish the right mounting hole to mount the gas cylinder. I welded 2 brackets to the roll bar for solid mount. I used some 1/2 thick 6061-T6 aluminum to make some new trunk hinges. I pressed in 2 steel bushings for the pivot hole. The result is a much smoother trunk lid opening and closing.
