71 Cuda Pro-Touring Build
Author Topic: 71 Cuda Pro-Touring Build  (Read 193214 times)
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
Re: 71 Cuda Pro-Touring Build
« Reply #225 on: December 11, 2012 - 05:17:20 PM »
Playing around with some more aluminum. Lol    :roflsmiley:
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #226 on: December 12, 2012 - 08:44:41 AM »
You gonna make them for others i would like to know how much for my 71 cuda?
michele
« Reply #227 on: December 13, 2012 - 07:30:22 PM »
I can make them here, but would need an order 30 or 40 of them for them to be reasonably priced .  :bigsmile:
« Last Edit: December 14, 2012 - 11:24:23 AM by johns cuda shop »
Offline roadrunninMark
« Reply #228 on: December 19, 2012 - 03:03:08 PM »
Have you thought about making the front bumper brackets in aluminum (unless you already did and I missed it)?  That could save quite a few pounds.
Mark
« Reply #229 on: December 26, 2012 - 08:03:01 AM »
After shortening them over a 1" , I shaved off some 2 LBS off them . I also punched holes with dimple dies in areas of the car to save more,trying to concentrate more on the top half of the car to keep the center of balance low..I was thinking of making the upper door hinges out of aluminum plus some other parts. I have some scrap titanium around the shop I thought of using in some areas too. I am always open to Ideas from everyone here to shave more pounds off without effecting strength.
« Last Edit: December 26, 2012 - 11:20:21 AM by johns cuda shop »
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #230 on: December 27, 2012 - 09:14:11 AM »
Saving weight is going to be tuff without going fiberglass or carbon fiber on some or all the body panels.
On a street car I wouldn't sacrifice  a few ponds over safety and comfort, but the cool factor maybe...
Go Fast & Have Fun...
Offline anlauto
« Reply #231 on: December 27, 2012 - 10:09:28 AM »
I think the weight savings from a couple of holes in the dash frame will be made up in your console. I'm guessing the finished product weighs more than a stock Cuda  :banghead:
« Reply #232 on: December 28, 2012 - 02:26:34 PM »
  :iagree: save a pound here save a pound there ,it all adds up.I think i have saved 50 or so pounds so far with my billet parts and mods.I dont want to sacrifice comfort safety and driveablity for sure. But if i got the equipment and time why not? + I'm having fun!!! Fiberglass weighs more for the same strength though, personally I like all steel car myself, Having a AAR Cuda cured me from ever wanting a fiberglass body panel again.(Hence the poor quality and inferior durability) . Carbon fiber is the bomb....
« Last Edit: December 28, 2012 - 04:05:39 PM by johns cuda shop »
« Reply #233 on: February 08, 2013 - 07:43:56 AM »
Some more minor progress I had been busy with my business so the car has taken a back seat in the last couple of months. I moved my wheels out ( 1 inch on the rear and 1/2 on the fronts) I had to roll the wheel lips. I was about to do the ole baseball bat and jack routine to do them but I decided to try the Eastwood lip tool.  It worked well,l it took about a 1/2 hr a wheel lip. I also had to remove some floor pan material because the big 3 inch mufflers were only a 1/2 inch from the floor( I thought it was too close).This is the result of having the driveline angle at 1 deg down instead of the normal 3 deg . I will make a raised section over the muffler to give it some circulation . I still have a slight  issue with the pipes in the back . I want to get it at ride height soon to address that.
« Last Edit: February 08, 2013 - 05:00:42 PM by johns cuda shop »
Offline drewcrane
« Reply #234 on: February 08, 2013 - 09:19:37 AM »
Wow very nice , and thanks for posting up the pic of the fender roller ,I will have to invest in one of those looks very nice :2thumbs:
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #235 on: February 08, 2013 - 10:36:08 AM »
What IRS set-up are you using?  :drool:  You probably mentioned it, but i'm a dork and didn't go back to find it.
Offline willhaven
« Reply #236 on: February 08, 2013 - 12:33:17 PM »
From the looks of it, Reilly Street Lynx.
http://www.reillymotorsports.com/store/image.php?type=D&id=62
« Reply #237 on: February 23, 2013 - 01:06:36 PM »
Its a street lynx from RMS ,  I figured it to be the best set up to run the TTI 3 pipes out back without any major pipe interference , since Bill helped design the exhaust system for TTI around his rear suspension.
« Last Edit: February 23, 2013 - 02:20:37 PM by johns cuda shop »
« Reply #238 on: April 19, 2013 - 09:52:31 PM »
I havent post much in a while, Here are some pictures of some work I did making some flush mounted taillights. Trying to keep the theme of keeping the car with smooth transitions. The bezels are made from 16 ga CRS sheetmetal and will be welded fully into the tailight panel to lose the seam around the taillights. I plan on finishing up the body mods soon and loose end here and there to pull it down for paint this fall.
« Last Edit: April 19, 2013 - 10:01:19 PM by johns cuda shop »
Offline challenger4404spd
« Reply #239 on: April 20, 2013 - 12:59:52 AM »
awesome work as usual keep up the progress
