Author Topic: 71 Cuda Pro-Touring Build  (Read 193230 times)
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
Re: 71 Cuda Pro-Touring Build
« Reply #270 on: September 12, 2013 - 06:37:23 PM »
Removal of the XV type bars gained 3 inches of clearance. Now its easier to run my wires for the headlights ,fan ect...
« Reply #271 on: September 12, 2013 - 06:46:32 PM »
In order to hide the coils under the manifold, Indy makes a plate that mounts on the underside of the manifold once the factory plate is removed. I had to extend the coil power feed wires to make this work. Also the heater hose lines had to be modified because of interference. The LH side had to be removed and replaced with a flexible braided line.
« Reply #272 on: September 12, 2013 - 06:52:33 PM »
Looks better with the US cartool braces! :2thumbs:  I always was concerned with the other set up clearance wise.
Offline cordodge
« Reply #273 on: September 12, 2013 - 07:35:31 PM »
man you must have gone thru a ton of band-aids.  car looks awesome i would hate to guess how many hours you have on it.   bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline grimmey71
« Reply #274 on: September 12, 2013 - 11:35:17 PM »
Looking real good, any plans for an engine cross brace?
Offline wiging19
« Reply #275 on: September 12, 2013 - 11:56:48 PM »
I've enjoyed reading all the enhancements you've done and a lot of them I'd read about but not seen pictures of.  Always looking forward to see what you do next. :cheers:
« Reply #276 on: September 15, 2013 - 09:40:34 AM »
I had given it some thought. Due to the shaker Scoop being in the way it would be hard to use straight bends on the tubing. I would rather triangulate if I can..My thinking is,the way Bill has the Alterkation set up is the front coilovers mounts bolt to the lower frame so I plan on doing some stitch welding on the cowl ,floor and door supports similar like Aaron Beck had did with his car , But I dont really believe a shock tower brace its needed.   :bigsmile:
« Last Edit: September 15, 2013 - 10:16:17 AM by johns cuda shop »
Offline ToxicWolf
« Reply #277 on: September 15, 2013 - 10:14:28 AM »
Everything about the car is great, but your custom work is  :woo:
Just waiting for the next instalment.  :popcorn:
Offline grimmey71
« Reply #278 on: September 15, 2013 - 10:25:17 AM »
I stich welded ever seam on my Cuda and the difference was amazing, well not that I've driven it yet but while on rotisseriefloor pans tightened right up.
« Reply #279 on: September 19, 2013 - 11:17:33 AM »
Yeah Grimmey71, I plan on pulling the car apart this winter to finish the body anyway. Stitch welding some of the seams is on the what to do list, while its on the rotisserie .
« Reply #280 on: October 20, 2013 - 12:32:15 PM »
Since the trunk space is limited and I have the trunk panel in there to hide some of the wiring, I had to find a good compact spare. The spare tire from a 93-94 Mustang cobra fits well. The wheel has a deep and wide diameter to clear the big brakes, plus its 26" tall. One of the great things about it is the rim is aluminum and weighs only 21 lbs.. I was able to stick it in flush inside my trunk panel. I have to modify the back seat frame a little .
« Last Edit: October 20, 2013 - 12:34:09 PM by johns cuda shop »
« Reply #281 on: October 23, 2013 - 08:40:56 AM »
I agree that the shock tower brace over the engine is not needed , the whole front subframe takes the load , the upper bracing is a big help but the upper coil mount doesn't load against the inner fender at all
« Reply #282 on: October 23, 2013 - 08:50:18 AM »
I too used a Ford ( Lincoln )space saver rim and tire off a S-10 spare to get the sizing. I got the idea from this post! :2thumbs:
http://www.cuda-challenger.com/cc/index.php?topic=84451.msg844670#msg844670
« Reply #283 on: November 01, 2013 - 07:23:41 AM »
Yeah Brad,When I went to the junkyard, I looked at the Lincoln town car spare and found out the wheel needed to be slightly opened up for it to clear the axle register . The 93-94 Cobra spare had a larger opening and fit my axle shafts like a glove. Another plus was I noticed the dish in the center was big enough to clear the 13" brakes the Mustang Cobras had.
« Reply #284 on: November 01, 2013 - 07:27:48 AM »
That is true I did need to open it up some. :2thumbs:
