71 Cuda Pro-Touring Build
Author Topic: 71 Cuda Pro-Touring Build  (Read 194234 times)
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
Re: 71 Cuda Pro-Touring Build
« Reply #45 on: June 08, 2011 - 04:12:07 PM »
I added a cowl bar today,As I plan on doing some hard cornering with it (autocross ect.)This will add considerable ridgity to the upper cowl area. Made 4 Plates 1/8 inch for reinforcment , the bar is made from .120 wall 1 1/2 DOM 1018 steel.  One of the thing you will notice is I had to remove the factory bracing by the windshield. I plan on either modifying them or replacing with new braces.I had to also modify the steering column support and dash frame for clearance. Please note if you make this modification to your car you wont be able to use the factory instrument cluster
« Last Edit: June 08, 2011 - 04:17:13 PM by johns cuda shop »
Offline Moparinho
  • "Too many Ferrari and Lambo around me..."
« Reply #46 on: June 08, 2011 - 07:26:27 PM »
wow !!
never seen a cowl bar like that. :clueless:    Do you plan to build a cage ?   If not, honestly I don't think it worth.  The unibody suffers torsional rigidity not radial or lateral.  If you want to better handle steady corners,  I would have spent more effort to traingulate the front and rear area suspension areas.   The firewall nd the dash frame makes very big job to stiff that area.
Anyway, good luck and keep us posted.    :wave:
Paolo (Italy):
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383  (coming soon...)
'65 Shelby Cobra 427 Replica
« Reply #47 on: June 08, 2011 - 09:45:40 PM »
 :blah:,,Yes, I plan on running a 8 pt cage and tying into the cowl bar. I wanted to put this in first. Thanks
« Last Edit: June 08, 2011 - 09:48:25 PM by johns cuda shop »
« Reply #48 on: June 09, 2011 - 12:56:30 PM »
Offline hpe600rt
  • how sweet it is
« Reply #49 on: June 12, 2011 - 05:23:21 PM »
very cool :ylsuper:
« Reply #50 on: June 13, 2011 - 04:56:10 PM »
With cardboard as a template I made the lower supports for the roll bar loop. Using 1/8 thick plate I trianglated the rocker panel to the frame connector and the rear torque box area. With car level the seat in and roll bar mocked up temporary to get the position. I want to be able to use the rear door panels and rear window regulators so time spent here for careful positioning is a must. I am going to build the cage off the 1 3/4 .134 wall competition engeneering roll bar loop. With the seat installed the main loop is 6 inches from theback off the headrest.
« Last Edit: June 13, 2011 - 05:08:30 PM by johns cuda shop »
« Reply #51 on: June 16, 2011 - 06:42:58 PM »
I finished trimming the roll Bar today after check the hieght to the headliner. Then I took a measurment from the top of the bar to the rear frame rail. I ended up cutting into the back seat support area for the frame rail to main loop supports.After being happy about where I wanted the rear supports,  I  cut them and notched the ends. I sent them locally to be blasted and epoxy primed. I plan on a removable rear cossbrace and side bars When I get them back I will weld them in.
« Last Edit: June 16, 2011 - 08:17:44 PM by johns cuda shop »
« Reply #52 on: June 22, 2011 - 04:26:26 PM »
I drilled out all the spot welds and removed the Passenger side floor pan today, as ther were some major pin holes and felt it was best to replace the pan.  I can weld in the supports easier with this removed. The tunnel will be repaced after. I spent the rest of the day grinding the excess metal and cleaning up the frame.Coated the inside of the frame with rust bullet and all the mating surfaces with weld thru primer
« Last Edit: July 31, 2011 - 02:02:44 PM by johns cuda shop »
Offline TreeFrog
    • TreeFrog
« Reply #53 on: June 23, 2011 - 03:35:36 PM »
Great project, love the progress pics!
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
« Reply #54 on: June 25, 2011 - 08:36:40 PM »
Thank you for all the great comments. Not much to report other than i finished welding and smoothing welds on the Cowl seam, Engine compartment and the inner fender supports. I should be ready to install the Hemi engine to the T56 next.
« Last Edit: June 25, 2011 - 08:40:00 PM by johns cuda shop »
« Reply #55 on: June 28, 2011 - 06:18:36 PM »
With the Rear sump oil pan on. I moved onto installing the pilot bushing, Spec clutch disc , pressure plate. after indexing the belhousing and ajusting the hydraulic CSC for cushon ajustment I was then ready to install the transmission to the engine. I ran into 2 small problems. First was a clearance issue with the plate on the bell and a boss on the T56. I milled a a small hole (in the picture about 1 3/8 diameter and 3/16 deep. Now the plate fits flush. Then The CSC hose needed to be installed first before mounting the belhousing to the engine. To solve it ,After i installed the line to the CSC ,I just installed the belhousing to the transmission, than the tranny and bell to the motor.
« Last Edit: June 29, 2011 - 06:43:06 AM by johns cuda shop »
« Reply #56 on: June 28, 2011 - 08:50:13 PM »
Looks great! Shifter position/tranny sure looks long!
« Last Edit: June 28, 2011 - 10:17:41 PM by brads70 »
« Reply #57 on: June 28, 2011 - 09:11:20 PM »
Yeah,I agree. I was thinking the same today after I assembled it. I can change the position on the shifer location after I mount it in the car .
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #58 on: June 28, 2011 - 10:01:19 PM »
Lokks great! Shifter position/tranny sure looks long!
It looks that way but actully could come back another 6 inches in order to be close to our ebodys original location.  :screwy:
Go Fast & Have Fun...
« Reply #59 on: June 28, 2011 - 10:19:41 PM »
Wow!
