Author Topic: 71 Cuda Pro-Touring Build  (Read 194227 times)
Offline Mentally Challenged
Re: 71 Cuda Pro-Touring Build
« Reply #75 on: July 20, 2011 - 05:59:02 PM »
Looking great John.
Chris, Ohio
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #76 on: July 26, 2011 - 06:46:29 AM »
I want to say thank you for all the great comments everyone.  :wavingflag:
Offline GoodysGotaCuda
« Reply #77 on: July 28, 2011 - 10:01:24 AM »
Hello, with the Alterkation and the Street Lynx suspension,  I am running a 245 45 17 tire on the front with 17X8 rim 5.72 backspace and 1/4 wheel spacer. The rear is 285 40 18 tire with a 18X10 rim and 7.24 backspace. Overall you want to shoot for 26X9 on the front and 27X11 on the rear. This is the best combination I came up with without modifying the rear tubs. Those rims are bullet wheels with Nitto tires bought directly from American Muscle. Since this is going to be a triple black car ,I figured black wheels would set it off.  :bigsmile:
Sounds good, I'll have to check, but I think my 28.5" rears have a pretty decent amount to go before any tub modifications. They show it as being 11.5" wide, but I am on a 18x9" wheel. I'm tempted to have mine shot in a more satin black when I get some work done to the car. The gloss can look a little too "blingy" when the sun hits it right. But my car isn't black either!
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #78 on: July 28, 2011 - 02:47:16 PM »
I know what you mean, I am not a fan gloss black rims. I plan on repainting the rims Hot Rod Black (semi gloss) along with the grille, tailight panel and under the hood to give it a industrial type look.
« Reply #79 on: August 03, 2011 - 03:26:55 PM »
I began today by setting the Driveline angle to 1 degrees down by placing a jack under the the transmission mounting a protractor on the tailshaft. If you notice in the pictures that the T56 has a 4 degree slant from the mounting pad to the transmission crossmember. By taking a 1 1/2 X 2 block of aluminum I machined the 4 angle on the top mating surface. I boxed the crossmember with 1/8 plate and added to the lenth for 2 more mounting holes.
« Reply #80 on: August 04, 2011 - 10:30:56 AM »
Nice! If you wouldn't mind, I need to borrow that mill. Send it my way asap!  :dogpile:
1976 Dodge Warlock
« Reply #81 on: August 09, 2011 - 03:10:43 PM »
Lol ...It makes it easy for sure!!! Dont Forget the lathe too !!!
Offline Cuda Commando
« Reply #82 on: August 11, 2011 - 03:43:30 PM »
Enjoying watching this beauty evolve :bigsmile: Keep up the good work.
Offline bigblue73
« Reply #83 on: August 12, 2011 - 08:19:12 AM »
Great project John!  Thanks for ordering the Illumin8s.
« Reply #84 on: August 17, 2011 - 04:13:22 PM »
Thanks Tony! Awesome LED Parking light set up. Can't wait to try them.
« Reply #85 on: August 17, 2011 - 07:01:00 PM »
i spent the day installing the TTI headers and engine front accessories. The front engine accessory came in a kit from Bouchillion and had all the bolts , pulleys, line adaptors and belt. It sure saved time looking for these parts piece by piece. The TTI header install was flawless, I will need to clearance some of the tranny crossmember and floor slightly. As you can see I have plenty of ground clearance with the header collectors.
Offline Travis72
« Reply #86 on: August 18, 2011 - 01:32:02 AM »
Great progress!!  It's really coming together.  You are doing it the right way by putting it all together before paint.
Do you have the non-AlterKation specific TTI headers?  Just wondering because your driver's side header fits completely different than mine.
Travis
72 Cuda
« Reply #87 on: August 19, 2011 - 07:51:38 AM »
Hi Travis!!! Those are TTI part# TTI64LHCA-C5  , Made for the Alterkation and the 6.4 , 7.0 , and larger gen 3 Hemi. The primary tubes are 2" compared the the 1 3/4" that the smaller hemi uses. .
« Last Edit: August 19, 2011 - 11:53:13 AM by johns cuda shop »
Offline Travis72
« Reply #88 on: August 19, 2011 - 01:52:21 PM »
Ahhh OK.  Makes sense now when I look at the pictures.  Those are some big a$$ tubes.   ;D
Travis
72 Cuda
« Reply #89 on: August 21, 2011 - 06:25:35 PM »
The starter for the 130 tooth flyweel and a gen 3 hemi is MP part# P5249644AB . With the Keisler belhousing it has 1/2 13 holes tapped into it. I used the starter stud off a 70s mopar on the top. It required drilling out the holes in the starter. The motor has 2 bosses on the oil pan rail that needs to be ground off to sit flush with the motor, the holes don't effect the strenth of the engine block. See pictures 2-4
