Author Topic: Fabrication Work - Post it here!  (Read 14980 times)
Offline mopar12372
    • mopartech
Re: Fabrication Work - Post it here!
« Reply #15 on: March 12, 2011 - 12:48:41 PM »
 :iagree: plz just get a dana.
RESTO PICTURES
« Reply #16 on: February 01, 2012 - 03:06:46 PM »
Just finished making a valley tray for my 451" project. Used stainless button head socket head cap screws for the removeable plate.
« Reply #17 on: February 01, 2012 - 03:14:47 PM »
I was having trouble with fuel boiling on very hot days in traffic so I bought a new intake to experiment with. I adapted a bilge blower from a boat ( also used in racing to cool the brakes) I'm using a six pack style lid so it should hide the blower.
« Reply #18 on: February 01, 2012 - 03:19:34 PM »
I had a go at building my won strut rods and no one had adjustable ones with a rod end that mounted in rubber. They have been in use for over a year now and are working great! Sure makes adjusting the front end a snap! :2thumbs:
« Reply #19 on: February 01, 2012 - 03:39:41 PM »
If anyone wants to build your own sway bar tabs for the lower control arms, here is what I did.
« Reply #20 on: February 01, 2012 - 03:46:01 PM »
Viper caliper brackets to C-Body spindle
Offline Challenger III
« Reply #21 on: February 01, 2012 - 05:04:25 PM »
Casing spreader for a Dana 60:
I used 1/2" X 1-1/2" flat bar and 5/8" fine thread grade 8 fasteners.
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline hemiken
« Reply #22 on: February 02, 2012 - 07:09:45 AM »
 :popcorn: this is a way cool thread.................................... :wow: :bigsmile:
« Reply #23 on: February 02, 2012 - 07:15:10 AM »
Good job!  :2thumbs:
« Reply #24 on: March 05, 2013 - 12:50:22 PM »
Had to adjust the pinion angle for the new Dana with the composite springs so I machined up these angled shims (3degs) with the side parts built in to keep the u-bolts from contacting the composite spring.
Offline Tonker1
« Reply #25 on: July 02, 2013 - 08:25:53 AM »
Reading the intro to this thread, I'd have to say what I've made doesn't fit into the mechanical or electrical category, just the creative. My uncle used to run a bar which he closed recently, this left him with quite a few beer tap handles. He'd been wanting to use them as bottle openers and this is the solution I came up with.
The design is simple. One 20mm dia. stainless steel nut and one 3/8" dia. UNC Imperial 1" stainless steel bolt. Drill 8.5mm dia hole into nut, run a 3/8 tap into the hole. Cut the head off the hex head of the bolt and use a thread lock to hold place. Cut a small section from the nut such as in the images to create the final head shape.
Most beer taps use a 3/8" course thread so this design is universal and creates a unique and satisfying bottle opener!
Offline dutch
« Reply #26 on: July 02, 2013 - 09:54:56 AM »
 :) that will do the job.   Those handles would make pretty cool hotrod shifters too  :cheers:
*** Bart ***
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #27 on: July 05, 2013 - 04:40:02 PM »
Good stuff here  :popcorn:
« Reply #28 on: July 07, 2013 - 01:36:38 PM »
71 Cuda Aluminum Trunk hinges made from some 1/2 6061-T6 Aluminum Flat
« Reply #29 on: July 07, 2013 - 01:43:26 PM »
Cuda Sliding rear license plate . I made a slim line license plate light with LEDs to fit the sliding plate mods
