Author Topic: Changing Power Steering Fluid?  (Read 1004 times)
Offline 69ChargerRT
  • Its the car, right? Chicks love the car. - Batman
    • Daisy - My 1969 Dodge Charger R/T
« on: March 04, 2011 - 08:31:50 PM »
so how do you get the old fluid out?  mine is pretty ugly looking so id like to change it.  but i dont see a real obvious way of getting the old stuff out.
Offline the_engineers
Re: Changing Power Steering Fluid?
« Reply #1 on: March 04, 2011 - 09:35:14 PM »
Remove the hose clamp at the steering box and route the hose to a jug. Start the car and slowly work the wheel back and forth until you hear it groan.
You won't get all of it, and you might make a mess, but it's the only way I know of.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline femtnmax
« Reply #2 on: March 05, 2011 - 10:38:31 AM »
As the fluid drains out of the pump resevoir...shut the engine off and refill the resevoir.  Keep doing all the above until the fluid is coming out nice and clean.
Be sure to use approved power steering fluid and not ATF.
Phil
« Reply #3 on: March 05, 2011 - 10:44:48 AM »
Probably a good idea to replace the hoses while you're at it if they're old.
