Author Topic: Correct Oil for Speedo Cable?  (Read 1814 times)
Offline cwestra
« on: March 05, 2011 - 03:17:05 PM »
Is there a correct oil used for the speedometer cable?
Corey - in Northern Indiana
Offline femtnmax
Re: Correct Oil for Speedo Cable?
« Reply #1 on: March 08, 2011 - 09:06:50 PM »
There is a graphite lube made just for speedo cables, comes in a little squirt bottle.  Undo cable at speedo, and squirt entire bottle into cable.  Works great, better than engine oil IMO.   Have a towel to cover the carpet so don't risk a mess.   Napa or any parts house should have the cable lube.
If your more of a purist, undo the speedo end of the cable, then undo the trany end, and pull the flexible cable completely out of the housing.  Clean the cable real good, lather it with half the bottle of cable lube, then squirt the remainder in the speedo end of the housing as mentioned earlier.
Phil
Offline cwestra
« Reply #2 on: March 09, 2011 - 09:12:48 AM »
Thanks, I'll look for it.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: March 10, 2011 - 11:26:36 AM »
chrysler may a speedo lube, and it is like vasiline
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline lime73
« Reply #4 on: March 15, 2011 - 01:55:57 PM »
What should you apply to a new cable???  i just replaced mine and haven't installed yet.....
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: March 15, 2011 - 02:04:41 PM »
from the top side at the speedo end you Pull out the actual cable, If you have an original cable . clean it and lube it up and slide it back in,
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline lime73
« Reply #6 on: March 18, 2011 - 12:04:41 PM »
Should you lube a NEW cable?
Offline Rare_T_A
    • Freiss Family Mopar Site
« Reply #7 on: March 18, 2011 - 09:54:01 PM »
I use a product from AC Delco called Speedo Lube.
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
« Reply #8 on: March 26, 2011 - 11:02:08 AM »
A new cable should be lubed whenassembled but check anyway
Offline Matt70
« Reply #9 on: March 26, 2011 - 09:35:50 PM »
Years ago we'd use white lithium grease
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
