Author Topic: 383 exhaust manifolds  (Read 2408 times)
Offline browndevil
« on: March 05, 2011 - 11:31:03 PM »
I want to put a new exhaust system on my 70 Challenger 383 with auto transmission. I want to get a set of manifolds taht are correct for a challenger. It currently has casting number 2843992/2806900 which are not correct. From what I have been able to gather, it should have 2951865/2899879 but these seem to be harder to find and more expensive. I appears that 3751068/3751071 will also work and these are easier to find and cheaper. I don't require date/numbers matching. What is the physical difference between the two sets? Is it a difference in clocking of the mounting bolts? Any help would be appreciated.
Thanks,
Michael
« Last Edit: March 06, 2011 - 12:01:04 AM by browndevil »
Offline ted
  • 74 cuda, 70 challenger r/t
Re: 383 exhaust manifolds
« Reply #1 on: March 06, 2011 - 12:46:36 AM »
just have the pipes made for the manifolds you have.
« Reply #2 on: March 06, 2011 - 01:43:09 PM »
they all basically look the same , the clocking of the flange bolts changes
Offline cdawg
« Reply #3 on: April 25, 2011 - 01:46:52 AM »
The Late 1971+ have a larger crease on the upper edge of manifolds . Other then that...the manifolds physically are the same as the 70-71 production. I have a very good 1971+ pair with no pits if you are interested!
« Last Edit: April 25, 2011 - 02:45:11 AM by cdawg »
