Author Topic: 1968 440 oil pan and gasket question  (Read 1811 times)
Offline DocMel
« on: March 06, 2011 - 02:58:12 PM »
I just removed the oil pan off my 1968 date coded 440:
Besides the oil pan gasket that came off, there was also what appears to me, a metal gasket that is also part of a crankshaft splash shield or what some might call, a crankshaft oil scraper  (This shield also has a small slot in it to allow the oil pick up tube to run thru it):   If this is some sort off oil scraper, this is is also part something I havent seen in awhile, and only have seen in higher revving engines
Is this "splash shield/scraper gasket", something common seen in 440's?:   Its not a built motor;  This shield/gasket got wrecked removing the oil pan, and since I dont have a hi po engine, Id like to consider running without tif possible, and just reinstall the oil pan with a regular oil pan gasket
Re: 1968 440 oil pan and gasket question
« Reply #1 on: March 06, 2011 - 08:38:56 PM »
You should retain the windage tray inside and use the 2 gaskets to get the proper oil pick up clearance from the bottom of the oil pan.
Just researched and found this:
Windage tray and 2 pan gaskets must be used for proper pickup clearance.
Trays aren't much and they add a few horses.
Offline DocMel
« Reply #2 on: March 07, 2011 - 11:19:39 AM »
Thanks TC:  Thats exactly what I have:  A windage tray:  (For the life of me, I couldnt remember the right terminology)   Ill get another and 2 gaskets
« Reply #3 on: March 09, 2011 - 10:46:02 AM »
you can get a new tray & two gaskets from Mopar for less than the cost of of the two gaskets aftermarket
 Definatly reinstall it , I use Right Stuff sealant to prevent leaks
