u said it had set for 19 yrs,,how did u clean the tank? is it getting enough gas to run? is the gas filter clogged ?maybe you got dirt or rust in the carb. did you change the carb or fuel tank or the filter ? check your vacuum advance, that can hurt the running if its not working properly,,is it still got the original ecu on the firewall ? it could be going bad after sitting that long,,
