Author Topic: Ran great yesterday, now it won't start!  (Read 6323 times)
Offline EMCD
Re: Ran great yesterday, now it won't start!
« Reply #15 on: March 11, 2011 - 09:36:36 AM »
auto on the column
« Reply #16 on: March 11, 2011 - 09:42:46 AM »
If it's cranking interlock switch is not the problem....... Test for voltage getting to the ballast resistor..12V on & start position.
Offline EMCD
« Reply #17 on: March 11, 2011 - 12:28:34 PM »
ok, sounds good. the frustrating part is that it ran perfectly after i changed my coil, wires, plugs etc. it's just odd that the day after it all crapped out...
« Reply #18 on: March 11, 2011 - 12:35:56 PM »
Do you have the linkage that goes from the column to the tranny still ? If not the arm it attaches to has got to be in the right spot before it will start? ( In the engine compartment)
« Last Edit: March 11, 2011 - 12:55:26 PM by brads70 »
Offline EMCD
« Reply #19 on: March 11, 2011 - 02:50:18 PM »
i haven't changed anything on the tranny yet. it's all stock and the tranny is in park when I'm cranking it over
Offline GranCuda1970
« Reply #20 on: March 11, 2011 - 03:26:24 PM »
 Try this with a multimeter these guys know thier $#!7!! If it is low voltage they can offer further assistance.
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #21 on: March 11, 2011 - 05:29:57 PM »
check your voltage at the ballast and at the coil and check spark at the plug and check grounds as mentioned earlier and forget about how it ran the first day as sometimes crap happens when u replace things,we have all experienced the same effect,
72rtchallenger
what happens in the garage
stays in the garage
Offline mopar12372
    • mopartech
« Reply #22 on: March 12, 2011 - 01:38:44 PM »
i believe the ballast lowers voltage to 6-8 volts. check for voltage at the coil / ballast going in then out .
does it have spark? make sure the neutral safety switch is working or the car will not start. try to push the shuft lever all the way up and turn egnition key at the same time .
RESTO PICTURES
Offline EMCD
« Reply #23 on: March 12, 2011 - 05:39:53 PM »
so i finally got it going. i had to pump gas into the carb 4-5 times then it slowly started. when i took it out it shuddered under low speed, especially under light throttle load. it seems like the timing is off, that the best way to explain it. when i pressed on the gas at a light, it felt like it skipped. i checked all the wires, replaced the ballast, made sure the coil was in right and all connected and again this morning it wouldn't start. any ideas?
  • 72 to 70 clone
    • cardomain
« Reply #24 on: March 12, 2011 - 06:22:20 PM »
u said it had set for 19 yrs,,how did u clean the tank? is it getting enough gas to run? is the gas filter clogged ?maybe you got dirt or rust in the carb. did you change the carb or fuel tank or the filter ? check your vacuum advance, that can hurt the running if its not working properly,,is it still got the original ecu on the firewall ? it could be going bad after sitting that long,,
72rtchallenger
stays in the garage
« Reply #25 on: March 13, 2011 - 04:21:17 PM »
:iagree: first thing that came to my mind too. Fuel filter.
Offline EMCD
« Reply #26 on: March 13, 2011 - 07:21:11 PM »
we fully cleaned the tank, replaced the fuel lines and a new filter. the carb is all orignal and has not been rebuilt. the ECU is the original unit. i didn't see any loose vacumn lines when i changed the coil and wires.
Offline Barracudadan
« Reply #27 on: March 13, 2011 - 07:27:44 PM »
Maybe the fuel filter is plugged? I know you said the lines and tank were cleaned but who knows maybe there was some crud that got in there somehow and plugged it up, try removing the filter and put a piece of rubber hose in it`s place and see if it runs better.
Offline EMCD
« Reply #28 on: March 13, 2011 - 09:47:33 PM »
cool. I'll try that tomorrow. how much is a new ECU? are they pretty cheap?
Offline jimynick
« Reply #29 on: March 13, 2011 - 09:58:58 PM »
EMCD, you've never answered any of the questions regarding whether this thing has spark at the plug or not. It's impossible to help when you can't eliminate some of the variables. Now you say it started, ran lousy and won't start again and it sounds fuel related, but maybe not because we still don't know about the ignition. For the second time, pour 1/2-1 oz or 15-30ml if you're a metric man, down the carb and see if it'll fire- if it does, then at least you know it's fuel and most likely in the old, dried out and/or bunged carb.
