Author Topic: M1 Intake  (Read 659 times)
Offline 19Cuda74
M1 Intake
« on: March 07, 2011 - 02:14:45 PM »
Soon I will have a stroked 360 magnum with a M1 intake. Currently I have a stock 340. Currently I have a air gap on the 340 and I have the coil mounted to the intake. With the M1 it doesnt look like I have that option. Suggestions? Also, will I need to modify any linkage to make this swap?
« Last Edit: March 07, 2011 - 09:22:45 PM by 19Cuda74 »
Re: M1 Intake
« Reply #1 on: March 07, 2011 - 11:55:46 PM »
I often use the 6 pack coil mount braket , you can mount the coil almost anywhere
Mancini has adjustable throttle cable brackets available to help set up the linkage , it may work as is from the air gap linkage though
