Paint Codes for TA Hood & Rear Spoiler
Author Topic: Paint Codes for TA Hood & Rear Spoiler  (Read 3142 times)
Offline challengermaniac
« on: March 11, 2011 - 01:35:07 AM »
Were the TA Hood & Rear Spoiler the same paint code color (please provide paint name & number)?  Of the two TA's pictured, which Hood shine more closly resembles the factory color?  I prefer the more flat black Hood of the Purple TA-----, so do I just tell my body guy to make sure he goes in that direction and then put a little more shine on the rear spoiler to match that of the TA side stripes?  Fairly inexact approach.
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Re: Paint Codes for TA Hood & Rear Spoiler
« Reply #1 on: March 12, 2011 - 08:35:48 AM »
Can't answer your first question, but for an opinion on your second question, I think you should paint it the flat black if that is the way you would like to see it. That way, when you go outside and look at your finished car you think "that car looks just the way I wanted it" as opposed to " It looks good but, I wish I had painted the hood flat instead of semi-gloss".  :2cents:
« Reply #2 on: March 12, 2011 - 06:21:06 PM »
I painted mine flat black. I gotta warn you it's impossible to keep that way. It shows every drop of water and you will have no way to clean it without making it a satin finish. I bit the bullet and waxed mine to give it the finish it has now. :2cents:  easy to clean now.....
Alaskan_TA
« Reply #3 on: March 12, 2011 - 08:01:29 PM »
Both were Organisol, see http://www.hamtramck-historical.com/images/TSBs/1969/D69-23-10.jpg
It is very common to see it sprayed too 'dry'. It does have a very light texture when properly applied. If you run a cloth over it & it snags fibers it was done wrong.
To avoid water spots, pat dry with a terry cloth towl after washing.
« Reply #4 on: March 13, 2011 - 10:50:21 AM »
Barry...Guest?
« Reply #5 on: March 13, 2011 - 12:57:01 PM »
Barry...Guest?
Oh great now he left too? What's going on around here? :banghead:
« Reply #6 on: March 13, 2011 - 01:03:28 PM »
I'm assuming it has something to do with this.......
http://www.cuda-challenger.com/cc/index.php?topic=75141.msg766232#msg766232  :o
Quote from: Alaskan_TA on March 11, 2011 - 11:28:29 PM
Historically, the photos disappearing has always been this site's #1 complaint.
The automatic advertising to each post may soon replace it?
just gonna have to get used to that.  its not going to change.  weve been working very hard lately to keep this place going and the advertising has become necessary for a variety of reasons.  i appreciate your input but i no longer need your constant commenting on this issue, especially in topics that dont have anything to do with it.
« Reply #7 on: March 13, 2011 - 04:19:22 PM »
I would think there must be a little more to it. 69 was obviously a little irritated, but the comment doesn't seem to me to enough to cause anybody to pack up and leave (by itself). But i've been wrong before....many times... :2cents:
« Reply #8 on: March 13, 2011 - 04:29:31 PM »
Notes I saved on painting Organosol:
If you want the 88% correct textured finish you must use DDL9355 Lacquer. 88% correct because the texture additive changed slightly from the orig. If you want the catalyzed, semi-gloss, smooth sheen finish enamel it's DCC9355...
Organisol Black Revised 01-2009
You must lay the paint down wet or the texture will stand up instead of lay down and you will have an extremely rough finish that attracts everything.
Use the slowest thinner you can find and add some retarder as well if it is above 80 degrees. If possible use over black primer.
Allow surfaces to dry for several weeks before painting cover coats. This is important.
Put 2 light cover coats of semi gloss black over grey primer, allow to dry at least 24 hrs or more before organisoling
Use a gun with a big tip 1.4mm or larger
Cross coat the large area surfaces in 3 directions –eliminates streaking of texture diag first, short length, long length with overlapping passes. It must go on wet.
Test spray before committing to car. Practice a little. Use SLOW thinner !!!! Lay on WET!
Do not lay on dry, paint horizontal.
Patience!!!!! Thin per instructions min 150%
After getting full coverage of texture typically 4 coats thin each progressive coat 25% Use your judgment Think about 6 coats.
Allow each coat to dry for at least 30 min.
Texture must cover surface completely-there should be no gaps in the texture. The purpose of laying it on cross coating & wet is to get the texture to lay down. I am no expert, but I do paint and I have done my fair share of wresting with this paint.
Edge it in with a touch up gun,
Use fine line tape on all paint edge breaks
Do the bottom side of the hood first-part of your practice
Paint All other surfaces at the same time as the top side of the hood.
Make sure grille is out of the car
Across the tops of the fender & across the front header panel be sure to add 1 extra coat of Organisol to resist the long term wear of the paint from stones etc..
