Author Topic: Does it make a difference: sound deadening insulation?  (Read 4250 times)
Offline Super Blue 72
    • Phil's Super Blue '72
« on: March 13, 2011 - 05:35:57 PM »
Just wondering for those who have put in some sort of sound deadening material like Dynamat, does it make a big difference if you drive with the windows open?  Is it worth it?  :dunno: Just curious.  Thanks in advance.  :)
Offline Slotts
Re: Does it make a difference: sound deadening insulation?
« Reply #1 on: March 13, 2011 - 09:12:32 PM »
Hey Phil,   :wave:
I think if you have an A/C car, it might be worth it, but otherwise I don't see the need for it. Like you said with the windows open all you want to hear is the roar, right?  :grinyes:
Slotts
« Reply #2 on: March 13, 2011 - 10:05:12 PM »
Hey, Jim!  :wave:
Thanks for the reply!  Yeah, no AC for me.  I have the interior out and was hopefully this spring put it back in and didn't know if I should do the insulation route.
One big issue is that I will sometimes get water inside the car from a hole in the cowl somewhere and figure if I have less stuff under the rug, the quicker it will dry and not hold moisture.  Yeah, so probably best no insulation stuff.
Besides, I need the windows open to listen for parts falling off the car.   :bricks1:   :roflsmiley:
Offline Final Challenge
« Reply #3 on: March 16, 2011 - 10:01:50 AM »
I'm looking into using Lizard Skin to insulate from heat and sound. It is spray on and sandable.  You can also paint over it.
Offline Jesus H Chrysler
« Reply #4 on: March 16, 2011 - 11:44:13 AM »
One of the things the undercarpet insulation does is reflect heat from the exhaust to keep the interior cooler.  My Challenger has a 440 with headers and it gets really hot from underneath.  It also deadens the sound reflection from the road.  My car had turndowns after the mufflers before the axle for a little while.  Even with the top down the noise in there was horrendous.  I put the carpet in loosely and it quieted down some.
To calm your leak fears try this:  Put a small hole in the dynamat or whatever you use right over one of the factory body plugs in the footwell.  Then put a few pinholes through the plug to allow any water that collects to escape. If you get the foil lined dynamat it will act like a barrier between the moisture and the metal of the floor.  I know it's just a stop gap method until you get the moisture problem figured out, but it will help you with your short term problem.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
« Reply #5 on: March 16, 2011 - 07:49:04 PM »
Thanks for the input guys!  :thumbsup:
Lizard skin?  Interesting, I'll look into it.
Thanks for the tips, JHC.
 :bigsmile:
« Reply #6 on: March 16, 2011 - 08:56:53 PM »
I've always thought the sound of these cars is part of the character, but I agree with JHC, the exhaust really heats up the floor. I'm thinking of putting some just on the area between the seat and firewall.  :2cents:
Offline mojavered
  • Someday!
« Reply #7 on: March 17, 2011 - 12:22:41 AM »
:roflsmiley:  I like it!  I just went to the fabric store and bought that aluminum sided wool stuff by the yard.  It was cheap, maybe 30-45 bucks for the whole car.  I have just enough to do my roof.
Jason
« Reply #8 on: March 17, 2011 - 10:18:13 AM »
Yeah, the sound of these cars is like music to our ears.  :grinyes:
Aluminum sided wool stff?  Sounds interesting!  I'll check it out!  :thumbsup:
Offline dutch
« Reply #9 on: March 17, 2011 - 11:11:23 AM »
I love the sound too, but I don`t care for resonance in the bodypanels. Stuff like dynamat eliminates it pretty good.
*** Bart ***
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« Reply #10 on: July 05, 2011 - 11:10:33 AM »
Holy Christ I thought I was the only one...  :roflsmiley:
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Offline Strawdawg
    • Vortex Buicks
« Reply #11 on: July 06, 2011 - 01:29:20 PM »
sound deadner does not stop the noise...it changes the characteristic by changing the resonance of the panel
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #12 on: July 06, 2011 - 07:54:32 PM »
