Author Topic: What is this interior bracket?  (Read 1043 times)
Offline 'Cuda Hunter
  • Tastes Like Chicken
« on: March 13, 2011 - 10:41:13 PM »
What is this for?
It is on the passengers side, just above the floor.  Facing forward.
Re: What is this interior bracket?
« Reply #1 on: March 13, 2011 - 10:44:06 PM »
I think that hooks through a grommet that was in the OE carpet...repro carpet does not have
  Mine had something like that on both sides
« Reply #2 on: March 13, 2011 - 10:49:25 PM »
So it is for something that no one uses...?
« Reply #3 on: March 13, 2011 - 11:17:13 PM »
I cut a slit in the carpet...it does help keep the corner from slipping I suppose.
« Reply #4 on: March 13, 2011 - 11:20:16 PM »
If you look right in the middle of the slot, you can see where there used to be a bolt or a washer and bolt.
The rust spots in the middle.
Had to hold something.  Was it just for holding the carpet?  Seems ugly for just that.
« Reply #5 on: March 14, 2011 - 07:32:51 AM »
I suppose the grommet could rust, it is all covered by the rear interior panel so it's not seen. When installed it is bent over not straight as in your picture.
