Author Topic: When welding roof to quarter panel , how do you remove all the lead  (Read 1411 times)
Offline 74BlueFish
Hi ,
Getting ready to install the roof.
When welding roof to quarter panel , how do you remove all the lead from the seam area to MIG weld.   I read the post on what filler to use or to re-lead.  But pretty sure I can't remove the lead from the seam so welding won't work
What have you guys done?.
Thanks for any sugestions.
Dan
Dan
Offline 72cudamaan
Re: When welding roof to quarter panel , how do you remove all the lead
« Reply #1 on: March 16, 2011 - 11:38:52 AM »
Heat the area with a propane torch and when the lead becomes shiny wipe it with a wet rag. Keep doing this until it's clean. Then use a metal wash to remove the residue.
And wear gloves. The wet rag will steam and get quite warm.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 74BlueFish
« Reply #2 on: March 16, 2011 - 01:45:00 PM »
Thanks Andy,  I'll try that.  Grinding wasn't working,   and I knew it wouldn't weld.
Dan
Offline dutch
« Reply #3 on: March 16, 2011 - 03:34:05 PM »
make sure you wear a decent dust mask grinding or sanding that stuff
*** Bart ***
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #4 on: March 16, 2011 - 06:26:19 PM »
propane torch and a wire brush works perfect. Make sure you wear gloves. and if you are a smoker dont smoke while messing with lead. You can easily get lead poisoning.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline 74BlueFish
« Reply #5 on: March 16, 2011 - 07:08:03 PM »
OK,  Thanks for the safety requirements.
Dan
