Author Topic: trunk light wire routing?  (Read 6531 times)
« on: March 20, 2011 - 12:29:04 PM »
Does anyone have a picture of how the trunk light wire routes after it comes out of the deck lid?  Does it run to the inside or outside of the trunk hinge?  Take a look at this picture.  Do I have the black clip in the right place.(in the hole that's in the trunk hinge)  Thanks
Offline Katfish
  • 70 Challenger
Re: trunk light wire routing?
« Reply #1 on: March 20, 2011 - 12:33:51 PM »
 :popcorn:
Offline BIGSHCLUNK
« Reply #2 on: March 20, 2011 - 12:53:07 PM »
I 'd like to see this myself....
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #3 on: March 21, 2011 - 07:31:37 PM »
Anyone have a factory installed trunk light?
This is the only picture I've found so far.  I need to know where the wire goes AFTER it comes out of the black clip on the trunk hinge.  Thanks
 http://board.moparts.org/ubbthreads/upload2/4611628-05.jpg
Offline FY1Cuda
« Reply #4 on: March 21, 2011 - 09:13:16 PM »
Our '70 Cuda has the factory installed trunk light, and it's just like you show in the picture.
« Reply #5 on: March 21, 2011 - 10:10:55 PM »
I need to know what path the wire takes to get to the tail light harness.  Does the wire run into the trunk on the inside or outside of the hinge.  Does it clip into anything or does it just run diagonally over to the tail light harness?  Can you take a picture for me?  Thanks
Offline 67vertman
  • Member since 9-23-2005
« Reply #6 on: March 21, 2011 - 10:40:14 PM »
I saved this a while ago, it;s for a 70 E-Body........I hope it helps!
« Reply #7 on: March 21, 2011 - 11:27:10 PM »
That's for the neutal safety switch harness not the trunk light....BUT thank you for posting that.  I'm not sure if I have the clips installed on the trans right.  That's one less question to ask in the future. :thumbsup:
Offline Canadian Cuda
« Reply #8 on: March 22, 2011 - 01:37:26 AM »
my trunk light wire in my 70 was never removed. it ran down the outside of the hinge, inbetween the quarter and trunk support the into the wiring harness. i can take a pic if you'd like.
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
Offline Katfish
  • 70 Challenger
« Reply #9 on: March 22, 2011 - 06:25:06 AM »
Pic would be great!   :popcorn:
Offline HemiOrange70
« Reply #10 on: March 22, 2011 - 10:38:49 AM »
Someone posted this link-it has a pic of the wire you need to see
http://www.moparaction.com/Article/PoP/Q.jpg
Offline 67vertman
« Reply #11 on: March 22, 2011 - 11:25:30 AM »
 :bricks1:  My Bad, I loaded the wrong photo.  :bricks1:
Here is the right one.
« Reply #12 on: March 22, 2011 - 12:49:29 PM »
Interesting...the picture of Dave Waldens car has the clip on the inside of the hinge while the factory drawing shows the wire clip on the outside of the hinge.  Obviously the line workers put them where ever they felt like it.
A picture of inside the trunk would still be nice though.
Offline LAA66
« Reply #13 on: March 22, 2011 - 10:51:53 PM »
 Can't say this setup is correct or not, but everything else looks nice.
 Maybe back then it was just the luck of the "spool bend" as to which side to route. I'd say Position the wire so the hinge doesn't pinch it and be done.  :2cents:
« Reply #14 on: March 22, 2011 - 11:05:57 PM »
I routed the wire how the factory drawing showed it.  I wrapped it around the back side of the hinge and installed the clip on the left side.  By looking at the bends that were present in the wire, it looks like it is installed correctly now.
The only issue I have now is that with everything hooked up, there isn't enought slack in the dome light harness to clip it in the topmost strap on the wheelwell.  Maybe I have the dome light harness in wrong. :bricks1:
