Author Topic: drum to disc donor cars?  (Read 2050 times)
Offline Dark Horse
  • 70 Cuda ,69Mach 1,70 Charger RT/SE
« on: May 20, 2002 - 11:31:20 PM »
converting the front drums on a ebody to a disc brake set up, what type of none E body cars can we use as a donor for the setup?years/models?
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
When you see the Dark Horse...take heed
hell is coming to breakfast......
Re: drum to disc donor cars?
« Reply #1 on: May 21, 2002 - 03:00:16 AM »
70- 78 B bodys & 75-80 F body Aspen/Volare
« Reply #2 on: June 04, 2002 - 02:55:49 AM »
WARNING
The 70-72 B&E bodies use a smaller spindle & a smaller inner brg if they are a matched set they work fine but the later 73 & up B & E bodie rotors with the larger brg will fit on the small spindles & use the same outer brg so make sure you check the inner brg on the spindle to be sure it is the correct size  ;)
« Reply #3 on: January 03, 2009 - 12:56:37 PM »
A body spindles also work from 73-75
Offline Roppa440
« Reply #4 on: January 03, 2009 - 04:06:01 PM »
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
Offline Katfish
  • 70 Challenger
« Reply #5 on: January 03, 2009 - 09:09:16 PM »
WARNING
dr diff now has a spacer/shim that converts the smaller diameter spindle to the larger size.
