Author Topic: Goop that will seal in oil  (Read 1155 times)
Offline shadango
« on: March 31, 2011 - 09:29:40 PM »
So I have an oil pan on my 2003 Durango that has a problem with rust scabs.  Not sure why....but they are big blisters.   Well, one started seeping oil.....so I drained the oil, cleaned everything up and used JB weld. But oil ended up seeping thru anyways.   Its not an emergency yet, but need to rectify.  Changing the pan will mean either lifting the engine part way out or dropping the rack and front axle/diff.....both are a lot of work and will take time.....so looking for a semi-temporary fix.....
Anyone know of any type of sealer, etc that I can use that will work even if there is some oil there?
I know it sounds like a lazy-ass question....but I need the truck daily and cant have it tied up in the garage being worked on for weeks like I can do with the fish....
Any ideas?
Offline mopar12372
    • mopartech
Re: Goop that will seal in oil
« Reply #1 on: March 31, 2011 - 09:34:42 PM »
there isnt anything out there available to the public that will help (glue that is).
RESTO PICTURES
Offline shadango
« Reply #2 on: March 31, 2011 - 10:11:18 PM »
I saw somewhere a product that Permatex makes....a spray sealer....called spray and seal....for leaks and such...
For the price I may try it....
I really dont want to drop that pan.
Offline Challenger III
« Reply #3 on: March 31, 2011 - 10:23:46 PM »
Wow, I used J.B. Weld on a gasoline leak before with success! It must have something to do with the changes in temperature from idle to running.
Try this stuff:  http://www.acehardware.com/product/index.jsp?productId=1409482
Good luck!  :cheers:
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
« Reply #4 on: April 01, 2011 - 08:28:30 AM »
No experience with anything in this area but I'm thinking a patch a couple of inches larger in each direction than the hole, scuff & clean the surface along with a suitable adhesive.
Offline shadango
« Reply #5 on: April 01, 2011 - 05:26:28 PM »
I think my issue is that even after it sits empty of oil for a while , there is still enough trace oil left in the hole/bubble area that it seeps thru and ruins the seal....
I dunno.
Gonna try something one more time.....I guess.
Offline Jesus H Chrysler
« Reply #6 on: April 01, 2011 - 09:03:58 PM »
I agree with Bullitt.  If you try to apply something directly on the hole you get a couple problems.  1 the metal is weakened with rust and is flexible enough to wreck your repair and 2 it's soaked in oil.  The hole is permeated with it, nothing will stick directly to it.  I think if you follow Bullitts suggestion and patch it like you would a tire it may work better.  IE cut a piece of metal larger than the hole and use it to seal AROUND the hole rather than IN it.  If you allow it to cure properly it stands a better chance of actually sticking and resisting the oil that is seeping.  Another repair I've seen done by "redneck engineers" is if the hole is tiny, like just a weep hole, and it's low on the pan put a short self tapping screw in to seal it.  It won't be perfect but will keep most of the oil in till the repair can be made properly.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline Cuda54
« Reply #7 on: April 01, 2011 - 09:19:59 PM »
Use a heat gun and get it nice and warm then you sand the rust off then spray it off. With brake clean the heat will thin the oil so it will bleed out of any small hole. Then warm it up again if you see oil use the brake clean again. Once you get it clean and warm the use the JB to seal it. But it has to be clean and dry for the JB to hold. Heat will thin it and help it setup faster.
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #8 on: April 02, 2011 - 06:42:15 AM »
Been there, done that and it worked fine on an old lawn mower gas tank. But use a rubber "washer" on the screw for added seal effect.   :2thumbs:
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline shadango
« Reply #9 on: April 02, 2011 - 08:26:56 AM »
Thats a pretty good idea there......may try that.
My concern now is that I have slthered the problem areas with JB weld.....thinking i may have to remove some of that......and concerned I will make it worse....grrrrrr......
What a PITA
Offline mopar12372
    • mopartech
« Reply #10 on: April 03, 2011 - 11:30:29 AM »
good luck!
RESTO PICTURES
