Author Topic: Installing Powermaster 200A Alternator  (Read 8844 times)
Offline jforest1
« on: April 02, 2011 - 01:00:12 PM »
Powermaster part #8-47539 .  PM68 on Y1.  I'm trying to install this puppy to power a new sound system I'm designing.
Here's where I am:
What comes in the box (the long bolt didn't actually--they require you use your existing one so its shown here):
1st issue: New alternator has a 4-prong plug.  Looks like I'll need a harness.  I'll deal with this after its mounted.  Old alternator used a set of wires (red on output terminal to starter relay/positive; black also on output terminal and goes to ?ammeter?, dark green on horiz field brushing to voltage regulator, dark blue on vert field brushing to voltage regulator (and carburator solenoid)):
Moving on, old alternator with old compressor/new bracket:
Powermaster alternator not fitting:
Well, sort of fits here, but not while in the car:
Am I mounting this properly?
Need another quarter inch...ugh.
Now, if I rotate the alternator way up so that it matches the bracket, I can align the belts by using spacers on the main mounting bolt.  But I'll need new belts and will have to be very precise about their length (I only have a .5" to move) in the bracket.  I'll also need to figure out how to run the A/C hoses.
Lastly, its not intuitive how I should mount it to the bracket using the provided hardware.  No idea where the provided bolt goes.
I feel like I'm missing something here...this stuff isn't adding up...
JF
« Last Edit: April 02, 2011 - 01:29:26 PM by jforest1 »
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Offline Jesus H Chrysler
Re: Installing Powermaster 200A Alternator
« Reply #1 on: April 02, 2011 - 01:21:36 PM »
It looks like your banana bracket is too curved.  Do you have a stock one lying around to compare it to?
I'm thinking if it was a little shorter and straighter it may work.
{OO /===\ OO}
(OO==> <==OO)
Offline jforest1
« Reply #2 on: April 02, 2011 - 01:34:07 PM »
My old banana bracket (previously on my R12 compressor) and new one match up exactly.
JF
« Reply #3 on: April 02, 2011 - 02:54:59 PM »
Have you compared the mounting holes between the two alternators?  There is an obvious geometry mismatch there.  Maybe the top bracket on the new alternator is in a different position from the stock alternator?  If the banana bracket was either straighter, or moved further up its mounting position it looks like it would work.  I imagine the holes in the brackets don't help.
{OO /===\ OO}
(OO==> <==OO)
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: April 02, 2011 - 02:59:16 PM »
Can you space the alt back the 1/4" you need physically?  If so the just add a spacer in the front, you may be able to just cut the provided one, not sure on the banana bracket though.  Maybe make a cardboard template an cut/redrill the one you have?  Looks like if you shortened the fixed side you could get the rounded portion to clear the alt cooler.
Tom
Tom
Offline jforest1
« Reply #5 on: April 04, 2011 - 08:03:21 AM »
Thanks to your posts, I think I've figured out the intent of the two pieces.  One is for cutting to make the spacer on the main mounting bolt and keep the alternator stationary.
The second is to put in the banana bracket mount point to so that it can be tightened down/keep belt tension.  It needs to displace a cylinder already in the alternator.  Not sure, but I may have to press the existing one out.  They give you this piece separate so if you can right- and left- mount the alternator.
That solves the belt alignment problem, just have to do it.
Now, for the banana bracket--the old alternator was 6.5" center of main bolt to center of banana bracket bolt.  Both are mounted on opposite sides of the alternator.
The Powermaster alternator is 5.5" center to center and the bolts are on two adjacent corners of the alternator  (I only mention the latter because it means the topmost-part of the PM alternator sits higher than the original when at the same angle--full height of alternator instead of half-height, which is the reason I'm running into my A/C hoses).
What is now curious is the YearOne description...the alternator above this one in the catalogue says that "some modifications to the mounting bracket are required."  I assumed the omission of this statement on the PM one meant they weren't.
That's what I get for assuming, I suppose.
So...now I'm in the market for mounting brackets.  PM is my next contact, I suppose.
So back to the electrical stuff--this alternator is a one-wire alternator with an internal voltage regulator--so I can rip out my current external voltage regulator, yes?
JF
Offline bigblue73
« Reply #6 on: April 04, 2011 - 08:42:50 AM »
Try a turnbucke and right and left hand thread rod ends.  Cheap and easy and it looks good.
Offline jforest1
« Reply #7 on: April 04, 2011 - 09:43:10 AM »
Not following you...  What would I use the turnbuckle for?
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #8 on: April 04, 2011 - 09:58:35 AM »
he wants u to put a turn buckle where the banana bracket is supposed to go if it will fit. it will b straight and strong and gives u your adjustment point u need
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline jforest1
« Reply #9 on: April 04, 2011 - 10:31:24 AM »
Interesting.  Thanks for the suggestions.
I think at this point my COA is to:
1.  cut the banana bracket, grind it so that it is a fork and looks good.  This doesn't give me a whole lot of adjustment room but I might be able to loosen the bracket bolt and move both alternator and bracket to accommodate give me more movement range in the combination of the two.
2.  failing that, resort to turnbuckle solution.
Looks like I need a press/c-clamp to get the cylinder out to put in the secondary mounting screw.
Lastly, spoke with Powermaster tech and he said that the wiring disconnect on the back of the PM alternator is not actually used, but rather was grandfathered in from previous alternator.  Finally that whole 1-wire alternator phrase is making sense.  :)
Just need to confirm by looking at the wiring diagrams for the blue/green wires, but I *think* this means that I can cut the blue wire at the splice before the connection to the voltage regulator, and pull out the regulator.
JF
« Last Edit: April 04, 2011 - 10:33:32 AM by jforest1 »
Offline jforest1
« Reply #10 on: April 11, 2011 - 02:57:32 PM »
JF
So my google searches are failing me.  I'm looking for a nice looking turnbuckle.  Anybody got a link to something that would be 6" long in the middle (not fully extended, not fully retracted)?  Or simply just a place that sells them?
JF
Offline 422STROKER
« Reply #11 on: April 11, 2011 - 07:21:29 PM »
Try Summit Racing.
Tom
Rod End
Tom
Offline jforest1
« Reply #12 on: April 14, 2011 - 07:49:31 AM »
Try Summit Racing.
Tom
Rod End
Thanks!  Found them--man, just have to know the magic word.  Now I've got to find the 3/8-24 4"L turnbuckle body.  Is there a magic word for it on Summit as well?
JF
Offline 422STROKER
« Reply #13 on: April 14, 2011 - 09:34:16 PM »
Try their alternator mounting kits, I think they sell replacement center sections.
Tom :2thumbs:
Tom
« Reply #14 on: April 15, 2011 - 09:52:58 AM »
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400191848737+&viewitem=
item above is what they are referring to... I'd be at the local Tractor Supply to see if I could make one for $10.00
